Keep throwing a CEL code 72
Old Aug 1, 2005 | 04:08 AM
AntonioH's Avatar
Default Keep throwing a CEL code 72
I've already searched on this topic. I keep getting a 72 code. I have changed all plugs, cap, rotor, and plug wires. I've also did a valve adjustment after changing out the easier things first. Thanks in advance.
Old Aug 1, 2005 | 09:00 AM
RagingAngel's Avatar
Default Re: Keep throwing a CEL code 72 (AntonioH)
misfire in cylinder two...
last resort could be bent valves.....
time to do a leak down test and/or compression check.
Old Aug 1, 2005 | 09:06 AM
AntonioH's Avatar
Compression check was done, good on all cylinders. Only 38.5 k on the motor.
Modified by AntonioH at 10:17 AM 8/2/2005
Old Aug 1, 2005 | 09:39 AM
Mythias's Avatar
Default Re: (AntonioH)
Couldn't it be a clogged injector?
Old Aug 1, 2005 | 09:52 AM
AntonioH's Avatar
I thought about that one also. The idle isn't smooth at all right now.
Winlight
22
Feb 13, 2011 08:42 PM
sikcrx80
Oct 14, 2005 01:55 PM
propulsion1
Oct 29, 2004 03:24 PM
1hotintegra
Jun 11, 2003 02:07 PM
sagaprelude
Aug 3, 2001 12:00 PM
