CEL code 74 + high compression from compression test???
Old Sep 7, 2005 | 01:50 PM
SHystrdyGSRtdy's Avatar
Default CEL code 74 + high compression from compression test???
i looked up code 74 and it said misfire cylinder #4...
so i did a compression test and i got about 240 239 230 240 on my stock 99 gsr motor? anyways...
should i be worried?
doesn't seem like it's running any differently? but it couldn't have just been a random CEL going off...
Old Sep 7, 2005 | 03:13 PM
debogsr's Avatar
Default Re: CEL code 74 + high compression from compression test??? (SHystrdyGSRtdy)
those are very good compression results. i got 220, 200, 220, 220 not to long ago.
Your results will vary depending on the quality of the tester you use and how it is calibrated.
All you want is your numebrs to be close together.
I wouldnt be worried about a misfire.
DId you recently change what gas you put into the car? That will sometiems cause a misfire.
Old Sep 7, 2005 | 04:51 PM
mastamind's Avatar
I personally would check the fuel injector function in the fourth cylinder. Also there could be a fouled spark plug in that very cylinder.
Possible causes of a misfire detected in one cylinder.
Fuel injector clogging, fuel/air leakage
Fuel injector circuit open or shorted
Spark plug carbon deposits, fouling
Leaking/open ignition wires
Distributor malfunction
Valve clearance out of spec
Old Sep 7, 2005 | 08:51 PM
Default Re: (mastamind)
hmmm... those are a wide range of possibilities.. i don't think i have the time to check each and every one... well as for my comp. gauge... i used to have around 220 i believe a few years ago when i checked... but i don't remember stepping on the gas all the way last time i tested (resulting in 220)
edit: and yes, i've been switching between 89 and 91 octane (due to the insane gas prices)
Jakester9500
Mar 27, 2020 12:09 PM
stwokay
Aug 26, 2014 08:56 PM
Winlight
22
Feb 13, 2011 08:42 PM
gohonda
Mar 23, 2008 03:52 PM
zirac50
Mar 5, 2007 12:26 PM
