TAIL LIGHT DIAGRAM
Old 04-10-2006, 02:27 PM
EF8IGHT's Avatar
Default TAIL LIGHT DIAGRAM
Hey, i just did a pwr window and lock conv. on my 97 civic HB. everything works great except my tail light wont work? the brake lights do, as do the turn signals, just not no regular lights in the rear? i need to know thw colors that go from the rear to the fuse panel to see how/where i f*cked up
thanks
Old 04-10-2006, 02:39 PM
Spade's Avatar
Default Re: TAIL LIGHT DIAGRAM (EF8IGHT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8IGHT &raquo;</TD></TR><TR><TD CLASS="quote">Hey, i just did a pwr window and lock conv. on my 97 civic HB. everything works great except my tail light wont work? the brake lights do, as do the turn signals, just not no regular lights in the rear? i need to know thw colors that go from the rear to the fuse panel to see how/where i f*cked up
thanks</TD></TR></TABLE>
Does the bulb work? Have you tested that first to make sure it's not something simple you're overlooking.......I hate it when I don't check the easy crap first and it's that....
Old 04-10-2006, 02:40 PM
EF8IGHT's Avatar
Default Re: TAIL LIGHT DIAGRAM (Spade)
its not the bulb or the fuse
Old 04-10-2006, 02:48 PM
ccjustin's Avatar
check your connection to the p-lights (I'm assuming you made one) I had a solder joint break in half (not my install) on an accord and only the front p-lights worked, fixed it and all 4 worked
Old 04-10-2006, 02:51 PM
EF8IGHT's Avatar
Default Re: (ccjustin)
i dont know which one it is, which is why I NEED A DIAGRAM
Old 04-10-2006, 03:05 PM
ccjustin's Avatar
http://i73.photobucket.com/alb...t.jpg
there ya go, anyway if there is an aftermarket keyless or alarm in the car its tagged into the p-lights. just a suggestion , its a red/black in the kick or at the dimmer switch, behind the radio, a lot of different places. I'd start with that
Old 04-12-2006, 06:51 AM
EF8IGHT's Avatar
thanks, also my locks are messed up when i unlock it from the switch inside the lock unlocks and quickly relocks seconds after, before i can even open the door. i have been rollin down my window and using the key in the handel in prder to get out ? any suggestions
Beeken
12
11-11-2016 03:41 AM
VtecHachi
10-17-2007 10:58 PM
CrazyRexBoy
01-13-2007 07:14 PM
xintegr
08-21-2005 05:35 PM
Jdmglenn
10-14-2003 07:03 PM
Quick Reply: TAIL LIGHT DIAGRAM
