Help!
Old Aug 21, 2005 | 04:59 PM
xintegr's Avatar
Default Help!
both of my 98 integra rear parking lights don't work. i tried switching them to new ones and they still dont lite up. what do you guys think is the problem.
Old Aug 21, 2005 | 05:03 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Help! (xintegr)
Did you check the fuses? Also, note that the rear bulbs have dual filaments, are they both working? Do the front parking lights work?
There are 4 sets of parking lights on the rear of 94+ Integras. The very small corner ones, and the first filament of the brake light bulb in the brake light area. Which ones aren't working?
Old Aug 21, 2005 | 05:05 PM
xintegr's Avatar
nothing in the rear lights work. besides my reverse.
Old Aug 21, 2005 | 05:11 PM
shamoo's Avatar
Default Re: (xintegr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xintegr &raquo;</TD></TR><TR><TD CLASS="quote">nothing in the rear lights work. besides my reverse.</TD></TR></TABLE>
Okay, so the brake lights AND the turn signals also don't work? Did you check the fuses? Always check the easy stuff first.
Old Aug 21, 2005 | 05:14 PM
xintegr's Avatar
actually i havent check if my turn signal have work. ill check that later on. where are the fuses located? is it under the steering wheel to the left?
Old Aug 21, 2005 | 05:35 PM
shamoo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xintegr &raquo;</TD></TR><TR><TD CLASS="quote">where are the fuses located? is it under the steering wheel to the left?</TD></TR></TABLE>
Yes sir. That's where many of the fuses are located. Pop open the little panel above the hood release and there they are. There should be a little plastic diagram on the plastic piece you pull off listing all the fuse locations and amps.
If not.....I recently posted for someone what they are because he lost his diagram.
EDIT: Dammit...I can't find the post....hold on.
EDIT AGAIN: Found it....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo &raquo;</TD></TR><TR><TD CLASS="quote">Okay, I'm home now. I'm looking in my Helms and it shows everything. However, since I have to type it out, it might be hard to understand. I'll try my best:
Also look here, I will be reading them off in the same way (top left to the bottom, then top right to the bottom) as the one pictured in this thread: https://honda-tech.com/zerothread?id=1078786
Note that that thread is talking about a Del Sol panel. It's similar to an Integra's, but slightly different.
Starting from the picture's upper left "Spare Fuse (20A)" going down:
Spare fuse
Stereo radio/cassette player, Cigarette lighter (15A) yellow/red
Left headlight (low beam) (10A) red/yellow
Right headlight (low beam) (10A) red/white
Turn signal, hazard relay (10A) yellow/black
Dash lights, parking lights, taillights, license plate lights (10A) red/black
ECM, PGM-FI main relay (7.5A) blue/white
Daytime running lights control unit (Canada) (10A) white/yellow
Daytime running lights control unit (Canada) (7.5A) yellow/black
Gauges, clock, backup lights, maintenance reminder unit (10A) yellow
Wiper/washer system, moonroof relay, integrated control unit (20A) green/black
Rear window defogger system, A/C system, ABS control unit, Power mirror actuator (7.5A) black/yellow
Not used
Spare fuse
Starting from the picture's upper right "Spare Fuse (15A)" going down:
Spare fuse
Not used
Left headlight (high beam) (10A) red/green
Right headlight (high beam) (10A) red/blue
SPACE WITH NO FUSES OR ANYTHING HERE
Front passenger power window motor (20A) blue/black
Left rear power window motor (Sedan) (20A) green/black
Power door lock control unit (20A) white/green
Driver's power window motor (20A) white/yellow
Right rear power window motor (Sedan) (20A) yellow/black
Integrated control unit, Ceiling light, power antenna motor, data link connector (DLC) (7.5A) white/red
Not used
Moonroof motor (30A) white
Spare fuse
Hope I helped you out with my confusing typed out explanation.
If you notice, there are 14 fuse listings in the first list, and only 13 in the second. That's because, in the second, there's a space where there is nothing. No fuses, just an empty space of plastic.</TD></TR></TABLE>
ndccpf1
Mar 12, 2012 02:26 AM
EF8IGHT
Apr 12, 2006 06:51 AM
The Stance
Jan 9, 2006 03:05 AM
Jdmglenn
Oct 14, 2003 07:03 PM
