| Welcome to Honda-Tech! | ||
#1 |
could someone tell me how to adjust the TPS sensor real quick?
2000 Civic D16 - (RIP) 1994 Civic built d16 - (sold) 1993 Del Sol SiR - (current) |
#2 | ||
iTrader Rating: (1)
Put a voltmeter on the red/black wire (I think its that one.) One wire is 12V constant, one is ground, the other is what you want.
Make sure range is between .45 - 5.00
Honda Civic/Del Sol (1992 - 2000) should officially be renamed "noobie tech or appearance tech" cause these guys have no clue what power/performance is. Quote:
#3 |
okay, i hooked up a voltmeter today.. i hooked it up to the yellow wire and got around 3.. and nothing from the red?
#4 |
iTrader Rating: (1)
do have the ingition on?
#5 |
yeah, i had to turn ignition on to get any kind of reading
#6 |
iTrader Rating: (1)
You need the Red/Black wire.
So when you open the throttle or close it completely you only see 3 volts? At close, it should be 0.45 volts at Wide Open, it should be 5 volts. Do you have your TPS and MAP sensors swtiched? They look almost identical. |
#7 | |
#8 |
iTrader Rating: (1)
Not 100%but thats not the wire he needs.
#9 |
so i SHOULD be getting a reading on the red/black wire then....what if im not?
#10 |
Whether or not it's the wire he needs, you tell someone that one of the wires is suppose to have 12v on it when it's only suppose to have 5v, it could lead someone to thinking they found the 'problem'.
The rest of your advice is sound. It might not hit 5v at WOT though, maybe 4.5v or so.
#11 |
i was wrong...i checked it again...i have 3 wires going into the plug for the TPS...they are yellow,green/white, and red/blue. I hook up my voltmeter to the yellow and im pretty sure that its getting close to 5v and it doesnt move any when i give it gas. None of the other wires have a reading?? is there a problem here???
Modified by bmiller17 at 3:02 PM 1/20/2006
#12 |
iTrader Rating: (1)
tps is:
Yellow/Blue Red/black Green/blue I think you got TPS and MAP sensor switched backwards. |
#13 |
i dont even have a red/black on my MAP
#14 |
you need to probe the middle wire of the tps. readings should like everyone else said: ~.45v at idle, ~5V at WOT. sometimes it was a little hard for me to get a reading at first. had to play around with the tps a little.
H22 BAR Writeup: http://www.honda-tech.com/zerothread?id=1777220 http://www.hondamarketplace.com/show....php?t=2532267 |
#15 |
my middle wire was red/blue, and i played with it for awhile, but never got any reading... ill try again in the morning and see what happens
#16 | |
are you probing a plug on top of your TB or on the side?
you want the one on the (back)side, inline with the middle of your throttle plate and throttle
#17 |
no, im probing the plug on the backside for the TPS
#18 |
ok, for future reference of this post, first off to check it you want to probe the middle wire and use a osilliscope, your readings should be .47 closed to 4.53 at wot with no drop outs in between, if your readings are off to adjust it on most tps's you need to somehow get the screws to be screws again, i use a hacksaw, and back them out, take them completly out and get some new bolts, IAT's use the same bolts or glovebox bolts work well from a 88-91 civic always get extras of these from junkyards and BAM! you have a adjustable tps then just adjust it to the numbers above... most hondas use the same tps just fyi
-Jake |
#19 |
oops. didn't mean to post. sorry!
Build Thread - My 88 ED6 Daily - 97 Vr6 Passat Wagon |
#20 |
I just set mine 5 min ago to .45 at idle and 4.52 at wot and runs great
#21 |
im gunna be "that guy" and ask my question, i tested my tps the other day, and i know i probed the right wires and such because i was usuing my manual. mine read fine at .5v- 4.9v. but when opening the throttle slowly it was all good except between 1.9 and 2.0 it read (1.8, 1.9, 0.0, 2.0, 2.1) and so on the rest was fine, and releasing was also smooth? should i replace this thing? i have a 98 civic d16y8. my car doesnt want to accelerate well sometimes im trying to figure out why without paying for it.
#22 | |
Can you repeat that drop out at that same exact voltage every time you sweep through its travel? A digital oscilloscope is really the correct tool to use for that, but if you can repeat the voltage dropout every time, then the TPS does indeed need to be replaced. |
#23 | |
| Tags |
| 1992, 2000, 94, adjust, adjusting, civic, d16, honda, location, position, sensor, si, tech, throttle, tps |
