civic with b18c runs great until it warms up.. then bogs like a motha... my friend has searched long
Old 08-27-2003, 05:59 PM
  #26
C4wrx's Avatar
sounds like the o2 sensor
C4wrx is offline
Old 08-27-2003, 06:18 PM
  #27
slvrcivic97's Avatar
Default Re: (h22eg)
yeah, i have that same problem with my 97 dx except I don't have the swap, I only have the mini-me swap. Anyways, when I first start my car up for the day, it runs really great and vtec xover is very noticeable and pulls, but after the car is warm, vtec is harder to feel and it is alot harder to sound...It doesn't have a crisp engagement like when it's cold. I'm lost too.
slvrcivic97 is offline
Old 08-27-2003, 06:31 PM
  #28
Blazin Si's Avatar
Default Re: civic b18c runs great until warmed up.. Bogging like Crazy! Someone come here and help figure ou
i get a hesitation/stumble/whatever like that also...
only when in low RPM's and accelerating.
i haven't been able to figure it out.
Blazin Si is offline
Old 08-28-2003, 05:03 AM
  #29
SpyderZEX's Avatar
I pm'd Tom in hopes that he will be able to help us diagnose the problem.
SpyderZEX is offline
Old 08-28-2003, 06:36 AM
  #30
tvrsir's Avatar
i i would think that you have injector problems are all cylinders missing. take the cap out and see if that's a problem. also check the headgasket do a compression test .
tvrsir is offline
Old 08-28-2003, 09:04 AM
  #31
SpyderZEX's Avatar
Already changed my injectors.
Old 08-28-2003, 09:10 PM
  #32
djay86's Avatar
it was the spark plugs.. thank god.. finally..
thanks guys!
djay86 is offline
Old 08-28-2003, 09:20 PM
  #33
tour de france turbo's Avatar
i just want to say thank you to the HT poster who helped me through this problem, i would have been lost if not for you.
tour de france turbo is offline
Old 08-29-2003, 06:57 PM
  #34
hondamagic98's Avatar
i have a obd1 gsr swap and i have no problems at all.....
hondamagic98 is offline
Old 08-29-2003, 07:12 PM
  #35
thehatchninja's Avatar
i'm having the same problem as you guys... 94 JDM GSR swap
thehatchninja is offline
Old 09-05-2003, 11:26 AM
  #36
SpyderZEX's Avatar
Changed the plugs, and still having the problem.
so..... Bump
Old 09-05-2003, 01:01 PM
  #37
slowdx's Avatar
Default Re: (hatch22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch22 &raquo;</TD></TR><TR><TD CLASS="quote">note to self dont buy a obd1 gsr engine</TD></TR></TABLE>
note to self my obd1 gsr will own your h22 hatch
slowdx is offline
Old 09-05-2003, 01:15 PM
  #38
AMG
AMG's Avatar
Ok just to remind everyone:
Its not very smart to run your car hard or even to hit vtec when your engine is
cold. Let it warm up first before you cross-over , then again what do I
know, treat your motor how you like.
Now as for the problem.....Thats very odd, heat soak wouldnt be able to make
your car go from running good to misfiring/running like ****.
* However for the kid who said "note to self, dont buy a B18C......you might want to research a little more before you make a comment like that. Also to the person who said that they couldnt here vtec as well and it didnt pull as well when it wrmed up, its only natural for the car to run faster when it cold and loose a couple hp's when it warms up, due to the heat generated by the engine into the intake.
just my 0.2
AMG is offline
Old 09-05-2003, 01:40 PM
  #39
jensen's Avatar
Note to self, tune your obd1 gsr engine for best results.
jensen is offline
Old 06-01-2011, 08:10 PM
  #40
daniel_traj's Avatar
Default Re: civic with b18c runs great until it warms up.. then bogs like a motha... my frien
biggg bump.
engine is b18c7 in AUDM dc2r
how were the problems resolved guys? getting this problem now..
will be fine when COLD then in operating temperature it will bog/splutter/misfire.. ONLY when its cold and between 2-3krpm... fine above 3 all the way to 9k
really frustrates me!!! plugs are also white, but car is drinking too much? how does that work!!! NO engine lights of any sought. still pulls in vtec.
at the traffic lights id be waiting, then i take off and it just completly bogs down and the revs drop to around 600rpm but does not stall.. then i got to pump the gas to revive the revs up to above 3k..
any help PLEASEEEEEE
daniel_traj is offline
Old 06-01-2011, 08:23 PM
  #41
Former User's Avatar
You won't get replies in this old thread. Make your own and check the O2 sensor. \thread
Former User is offline
ekcivic2
12-21-2023 06:02 AM
derrickkong888
08-28-2012 06:43 PM
jonyb
04-18-2006 08:28 AM
94RedEGCoupe
05-20-2004 05:51 AM
jz98ctr
06-20-2003 05:03 AM
Quick Reply: civic with b18c runs great until it warms up.. then bogs like a motha... my friend has searched long
