does your car run with a blown head gasket?
Re: (pythoner)
oh. because my friend iis doing a mini me swap for me. and he just called and said i have a blown head gasket? how do you repair/fix this problem?
and what kind of "not running good" do you mean? thanks
H-T Poker champion
Re: (jdmstockeg6)
Step one: Remove head
Step two: Remove old head gasket
Step three: Replace old head gasket with new head gasket
Step four: Put head back on and torque all bolts to spec
You don't want to run with a blown head gasket. You will eventually destroy the engine.
It's not hard to replace, especially with the engine out of the car.
Re: (jdmstockeg6)
depends on where you go. I would prefer OEM Honda/Acura Headgasket because it was made with quality and those usually cost $100-$150 depending on where you go. I found one on ebay for $80 which is from OEM Honda. Felpro also makes one that i used in the past and it worked great. It never gave me a problem and you can find it at Kragen, PepBoys, Autozone. And the price is about $40 at Autozone. For a peace of mind, I would say OEM
Re:
http://www.slhondaparts.com
http://www.hondapartsdeals.com
I just replaced mine and Im pretty sure it didnt cost anywhere near 100-150. I picked up a head gasket, valve cover gasket and timing gear all shipped for about 190.
If you are on the west coast go with slhondaparts and if you are on the east go with hondapartsdeals... why do you ask? Shipping times
Re: (JayKayNidas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JayKayNidas »</TD></TR><TR><TD CLASS="quote">Its a tedious job. Could take a whole day if you arent really mechanically inclined like myself.</TD></TR></TABLE> Not hard, it takes an 1 1/2 hours. If your mechanically inclined like myself.
Re: (numberone)
go to streetimports.com.they have decent prices for heag gaskets and stuff. I biult my b16 with the gasket set they have and it pretty good. you can even specify how thick( layers ) you want the gasket to be.
Re: does your car run with a blown head gasket?
Just give a sealer a try before you go and get it replaced, it could save you a ton of money. Use something like Blue Devil or Bar's. Here's a link - Head Gasket Sealer | Head Gasket Sealant | BlueDevil
