Precision SC61 Turbo specs?
Old 01-05-2005, 06:04 PM
hybrixt's Avatar
Default Precision SC61 Turbo specs?
Does anybody knoes the specs on a Precision SC61 #6162E?
I have one, but don't really know the specs.
I couldn't find info anywhere else.
Old 01-05-2005, 06:13 PM
b16sedan's Avatar
Default Re: Precision SC61 Turbo specs? (hybrixt)
What specs are you looking for?
Old 01-05-2005, 06:17 PM
DefiantGSR's Avatar
does this help
http://precisionturbo.net/turb...=3026
Old 01-05-2005, 07:26 PM
SHystrdyGSRtdy's Avatar
Default Re: Precision SC61 Turbo specs? (DefiantGSR)
a precision rep on ht said there's 3 versions of the sc61
Old 01-05-2005, 08:04 PM
hybrixt's Avatar
Default Re: Precision SC61 Turbo specs? (SHystrdyGSRtdy)
i know, but i haven't found the specs on this specific part # 6162E...
Old 01-06-2005, 05:48 AM
Rod Short's Avatar
Thanks for your question. Sorry, but there is no such thing as a 6162E. We make a 6152E, 6169E and a 6176E. The first two digits refer to the compressor wheel while the last two reference the turbine wheel. If you look at the outlet on the compressor cover, we typically scribe one of those three numbers there for identification purposes. Hope this helps.
Rod Short
Sales Manager
Precision Turbo
Old 01-06-2005, 08:46 AM
b16sedan's Avatar
Default Re: Precision SC61 Turbo specs? (Rod Short)
What exhaust wheels come with each variant? The 76E is a P-trim turbine, right? So i'm assuming the 52E and 69E are Stage 3 and Stage 5 TO3 wheels, respectively?
Old 01-06-2005, 09:38 AM
Rod Short's Avatar
Default Re: Precision SC61 Turbo specs? (b16coupe)
You're on the right track.
The 6152E (intended for engines displacing 2.0L and under) comes with a T350 76 trim turbine wheel. In Turbonetics lingo, that's a Stage V wheel. We rate this turbo as capable of supporting up to 630-hp with proper tuning.
The 6169E (for 2.0 to 3.0L engines) has a T04 69 trim wheel and is rated at 650-hp.
The 6176E had the T04 76 trim, which is more commonly known as a P-trim wheel.
Hope this helps.
Rod Short
Sales Manager
Precision Turbo
Old 01-06-2005, 09:09 PM
hybrixt's Avatar
"Sorry, but there is no such thing as a 6162E. We make a 6152E, 6169E and a 6176E. The first two digits refer to the compressor wheel while the last two reference the turbine wheel. If you look at the outlet on the compressor cover, we typically scribe one of those three numbers there for identification purposes. Hope this helps."
Thanks for your help.
My compressor cover has 6162E written on the outlet, so i assume it was an error and it might be the 6152E...
Old 01-07-2005, 04:42 AM
Rod Short's Avatar
Maybe they just sneezed or had bad handwriting . . . I dunno
Rod
Mr. JDM-GSR
07-11-2004 11:43 AM
94sohcEx
04-05-2004 03:40 PM
graphic
01-21-2004 01:18 PM
reXem
08-31-2002 06:31 PM
Quick Reply: Precision SC61 Turbo specs?
