Transmission & Drivetrain Gearboxes, Differentials, Clutches
Short shifter slop
Old 03-02-2016, 06:08 PM
skratchyy93eg's Avatar
Default Short shifter slop
My 01 Ls trans has a lot of slop. Can anyone help me out with why that could be. OEM shifter bushings won't fit so I'm out of ideas. Any help would be great. Has short shifter.
Old 03-02-2016, 06:12 PM
Dur Da Dur
hondur's Avatar
Default Re: Short shifter slop
Did you check the shifter linkage u joint?
Old 03-02-2016, 06:16 PM
The bolt that goes through the u joint does move up and down even with the washers and stuff.
Old 03-02-2016, 06:56 PM
Dur Da Dur
hondur's Avatar
If the u joint isn't tight then you need to repair or replace the shifter linkage. I made a thread about, click on my name, statistics, threads started by hondur "proper shift linkage remanufacturing"
Old 03-02-2016, 11:47 PM
Shit Posts: 15
JDMswagSerf's Avatar
What short shifter are you using?
Old 03-04-2016, 05:36 AM
Not sure. It was on the car when I got it. I'm going to go try and find a new linkage at a pull apart or something.
Old 03-04-2016, 05:37 AM
Thank you for that. Probably going to try and find a linkage at a pull apart. Any websites you know that sell them?
WeakSauceEJ8
09-15-2011 03:38 PM
dr_latino999
22
01-15-2007 04:14 AM
gameknb
06-11-2005 07:32 AM
starbury
02-15-2005 09:58 AM
Sketch_hs
21
03-31-2004 12:51 PM
Quick Reply: Short shifter slop
