Transmission & Drivetrain Gearboxes, Differentials, Clutches
S80 hydro guts in YS1 case with Mfactory helical lsd?
Old 11-22-2011, 07:13 PM
Pay2play killa's Avatar
Default S80 hydro guts in YS1 case with Mfactory helical lsd?
Can this be done? I have a minty S80 hydro gsr trans but an EF hatch. I also have a YS1 LS transmission that isn't in great health. I want to put the S80 guts in the ys1 cable case and get an Mfactory helical LSD for drag racing. From what I gather internally the YS1 and hydro trannies are pretty similar.
Any ideas on this or will something not work? Also which LSD will I need, the GSR (14 bolt?) type? any crazy issues with bearings?
Old 11-23-2011, 07:39 AM
Gearspeed-Performance's Avatar
Default Re: S80 hydro guts in YS1 case with Mfactory helical lsd?
Everything will go right in the YS-1 case. If you want to use the GSR final drive with it you will order the GSR/Type R sized diff. If you want to run the LS Final drive then order the B16 sized differential. One of the great benefits of the YS-1 is the interchangeability with Hydro transmissions.
Be sure to check all your clearances
If you have any questions..feel free to hit me up. I do this swap with every EF I put together with a B-swap...its standard practice! LOL
Old 11-23-2011, 03:20 PM
nice, thanks again. I just replied to your pm. I guess since I already ordered the gsr i'll rock the gsr fd at 4.4. i think that sounds beter than the ls 4.26 I might keep the ls 5th though
Old 11-28-2011, 07:22 AM
Wise choice! The 4.26 just doesn't cut it! LOL
Good luck!
Civic89stdB16
04-26-2008 11:40 AM
bubba_crx
09-28-2007 05:51 AM
rkrone
09-21-2007 08:18 PM
4drferio
12-09-2003 10:19 PM
Quick Reply: S80 hydro guts in YS1 case with Mfactory helical lsd?
