Transmission & Drivetrain Gearboxes, Differentials, Clutches
Driver side CV axle not fitting (2000 civic with B18B1)
Old 06-26-2011, 11:06 PM
PaddyV's Avatar
Default Driver side CV axle not fitting (2000 civic with B18B1)
I have a 2000 Honda Civic EX 4 door sedan that had a B18B1 swap and auto to manual conversion done by the previous owner. He used an S80 tranny. The motor is from a 1997 Integra (decoded the VIN on the motor) that was originally an auto.
Today I was changing my CV axles, which were made for a 1997 Integra, and the driver side axle was different. On the inboard side, instead of a male end with splines along the whole length, it was a female end. The intermediate shaft has a female end where the axle goes. Check out the pics in the link below. Any idea what kind of driver side CV axle I need?
http://imageshack.us/g/714/imag0026o.jpg/
Old 06-27-2011, 05:21 AM
kyden's Avatar
Default Re: Driver side CV axle not fitting (2000 civic with B18B1)
you have 90-93 integra axles.
Old 06-27-2011, 04:31 PM
Seagull Management
94EG8's Avatar
Yep. And if you ever need a driver's side axle seal you'll need to order it for a '90 - '93 Integra as well.
Old 06-27-2011, 05:16 PM
bryse68's Avatar
All b-series passenger side axles are the same, only driver side is different depending on inter. shaft
Old 06-27-2011, 10:23 PM
PaddyV's Avatar
I got the correct part today and installed it, part number HO-8003 (rather than the incorrect HO-8121) from O'Reilly auto parts. Also got a new bellows kit for the driver side as it was torn. Yes, it was the CV axle for a 1990 Integra.
Lesson learned: When you buy a car with a swap already in it, be ready to find out these little quirks and nuances as you do repairs.
Old 06-28-2011, 05:47 AM
Seagull Management
94EG8's Avatar
I goofed, meant to put driver's side axle seal, it's fixed now, but yes, passenger's side are all the same.
stevenstixx
05-13-2014 09:48 AM
esean93
01-13-2009 04:24 PM
LastGenEK
19
04-04-2008 12:57 PM
integrawow
07-02-2007 02:20 AM
V8SHME8
25
02-18-2005 10:13 PM
Quick Reply: Driver side CV axle not fitting (2000 civic with B18B1)
