Input shaft bearing
Old 01-09-2006, 03:54 PM
incapearlcivic's Avatar
Default Input shaft bearing
Could anyone help me out, with some info on the input shaft bearing. When I have my 2001 civic in neutral with clutch out there is a loud whinning noise. Now the noise is getting really loud when I'm accelerating in 1st and 2nd gear. Is the problem caused by the input shaft bearing? Also do anyone know of a problem with clutch not disengaging, even in neutral car takes off. Dealership says the new Bully clutch plate is too thick and won't release enough???
Thanks for any help you can give me.
Old 07-09-2009, 06:16 AM
van6232's Avatar
Default Re: Input shaft bearing
hey man, i have a 01 civic with the same problem. honda told me it was a commen problem with the 7th generation civics. take a peek at this link it helped me. http://www.civicforums.com/forums/36...save-some.html
dwils
03-05-2011 12:24 PM
KHaoTiK
12
02-23-2010 02:29 PM
obuhmyuh
05-10-2008 08:23 AM
1kleenef
04-13-2008 11:12 AM
tei344
07-06-2007 06:11 PM
Quick Reply: Input shaft bearing
