bleeding caliper with broken bleeder
Old 12-12-2011, 05:43 AM
SQ is the SQUAD's Avatar
Default bleeding caliper with broken bleeder
snapped the bleadr off one of my rear calipers. is it possable to blled the line using the bolt that connects to the brake line?
i was going to unbolt the caliper. push the piston all the way in, fill the space with some old brake pads then bleed the caliper with the line bolt being the highest point. will this work?
Old 12-12-2011, 06:00 AM
MR.johnson's Avatar
Default Re: bleeding caliper with broken bleeder
Have you tried a reverse drill bit or ez out?
Old 12-12-2011, 06:40 AM
yeah. i am eventually going to get a new caliper. i tried heading it, i tried easy out, i tried soaking it with pb.
Old 12-12-2011, 11:00 AM
frankenghia's Avatar
i have had this happen and all i did was crack the line loose where it goes into the caliper to bleed it. It should work. Worked for me anyway..
Old 12-12-2011, 11:57 AM
ok, that was what i was asking.
Old 12-12-2011, 02:38 PM
MR.johnson's Avatar
Can't people fix things right? Why not take a few minutes and do it the correct way.
Old 12-12-2011, 03:03 PM
postman's Avatar
cracking the line will work fine.
Old 12-12-2011, 04:05 PM
i already tried everything i could to get the bleeder screw out. i need something that works until i can replace the caliper. if this method works what wrong with using it?
Old 12-14-2011, 04:21 PM
sc34dc4's Avatar
Yes it will work. No it's not the best fix but you already know that. It'll be fine to do and drive until you can pick up another caliper and swap them out.
Old 12-22-2011, 08:35 PM
10psiLsEf2's Avatar
as long as the air has a way to exit then YES itll work.
danteisme
Suspension & Brakes
01-26-2015 09:23 AM
WhiteOnRice
10-26-2007 11:50 AM
JG90CRX-Si
08-16-2006 07:22 PM
grenthang
14
12-04-2004 05:20 PM
Quick Reply: bleeding caliper with broken bleeder
