Suspension & Brakes Theory, alignment, spring rates....
New Wheel Bearing Play itr 5 lug
Old 01-09-2017, 06:27 PM
mayfly's Avatar
Default New Wheel Bearing Play itr 5 lug
Hey HT
Vehicle: 92 eg civic itr 5 lug conversion.
So the quick story i replaced the front wheel bearings, and upon inspection i noticed that the two front wheel hubs were bad. i ordered brand new oem wheel hubs and 2 new national bearings from advance auto. pressed on the wheel bearings and the hub and i noticed i still have a little play as it sits in the knuckle. i have yet to install the knuckle assembly onto the vehicle yet due to the play. is this normal? will the play go away once i tighten the axle nut after full assembly? thanks in advance
Old 01-09-2017, 06:37 PM
Tyson's Avatar
Default Re: New Wheel Bearing Play itr 5 lug
Yes.
Old 01-09-2017, 06:41 PM
mayfly's Avatar
Originally Posted by Tyson
Yes.
thank you very much!!! i was just worried it might some how be the knuckle its self
Old 01-10-2017, 01:04 PM
Tyson's Avatar
if you have the axle available, you can just tighten it to check.
the two inner races of the bearing are captured by the axle. otherwise it can come loose.
Old 01-10-2017, 05:14 PM
mayfly's Avatar
i haven't gotten around to check due to work. were working some long long hours(16 hour days) will be able to check on sunday when i get time off. ill update you. thanks
Old 01-10-2017, 05:30 PM
mayfly's Avatar
well i crawled out of bed and grabbed an old hasport axle i had lying around. tighter it up and sure enough it worked great(knuckle still removed from civic). it seems like it will work. I'm going to re-install it tomorrow or maybe sunday and ill give you all a final updated and post test drive. thanks again
Old 01-21-2017, 06:37 AM
mayfly's Avatar
just to give an update. upon further inspection i noticed that my upper ball joints had some play in them. so i got really mad and did what any pi$$ed off @sshole would do and ordered new ball joints top bottom, rear wheel bearings, every bushing i could orderer the entire vehicle, inner/outer tie rods, so after thats done ill give a final update. thanks again
Old 01-21-2017, 12:41 PM
Tyson's Avatar
You do realize 1992 was 25 years ago.... If it was the first time replacing any of those parts I'd be surprised.
Old 05-12-2019, 08:47 AM
Angelo Conward's Avatar
What ball joints did you order for the itr 5 lug conversion? Been in a bind on what ball joints to but on mine
L2ILL
10-22-2012 01:38 PM
jdmcivicracer89
11-10-2010 09:59 PM
HOODLOVER
10-26-2008 07:24 AM
spets
Suspension & Brakes
04-05-2008 05:31 PM
Chicano
11
01-19-2005 08:14 PM
Quick Reply: New Wheel Bearing Play itr 5 lug
