Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
04 pilot: possible EGR??? vtm-4 and check engine light on!
Old 03-17-2017, 08:14 AM
  #26
airheart's Avatar
Default Re: 04 pilot: possible EGR??? vtm-4 and check engine light on!
Thanks for responding. When my son comes over to look at it again, we'll look at the things you mentioned. We did find a number of rodent droppings, and from reading on a number of forums - it's a common problem for rodents to chew through the wiring to the knock sensor, causing those caution lights. I wonder if there's a wire to the a/c? Thanks again, gives us more to look for and rule out.
Old 03-17-2017, 08:53 AM
  #27
speedlever's Avatar
That is very true. I believe the replacement knock sensor wiring has been rodent-proofed.
Old 03-18-2017, 03:44 AM
  #28
speedlever's Avatar
Originally Posted by Civic_4life
ya the guy at autozone is a moron, my uncle took it there, maybe they had difficult language barrier, dude said he codes was found when there was a check engine light on....
reason i though it was coilpack was because
1: we changed sparkplugs all new
2: engine check light was flashing when i rev the motor, so that indicate it was misfire.
FWIW, I think some codes can only be read by the HDS or very expensive code readers. So it's hard to say whether or not the code being thrown was one of those or not. I have no idea why some codes are invisible to inexpensive readers.
Old 08-19-2019, 03:50 AM
  #29
shadowbay22's Avatar
Don't know if this will help anyone but, had the same issue with my 2005 Honda Pilot. Code said EGR issue and VTM4 light also on. After SEVERAL visits to a Honda Dealership (and 2 EGR Valves and a plenum Gasket) I finally brought it to a recommended local garage where he BLEW OUT THE EGR PORTS at NO CHARGE because I had him do brakes and oil change, the problem was fixed. He said Honda only does what the computer tells them and sells you parts and service but an experienced mechanic in the real world knows this issue by trade experience. HONDA SHOULD HAVE KNOWN THIS ALSO!!!!!
Old 03-29-2021, 03:08 AM
  #30
hello, my uncle just brough a pilot, it runs and drives but its hestate little bit, i believe 1 or 2 cylinder is misfire due to egr?
so i went to start the engine today:
turn key on ll, vtm-4 flashes and goes off
start the engine, no lights,
then rev to 3000 rpm, vtm-4 light comes on, pretty sure its misfire.
from all research i did on google, everyone having problem with EGR or idle speed sensor.
anyone have this problem with their pilot? suppose to be common issue.
ill get code from autozone tomorrow, i work all day today.
thanks for any help in advance.!
EGR code came up, took it to Honda Dealership, they started to change expensive parts that didn't fix the problem. Took it to a local garage a friend recommended and he blew out the clogged EGR ports with compressed air and it was fixed He said 90% of the time this is the problem. Clogged Ports.
Old 03-14-2022, 06:31 PM
  #31
04 honda pilo's Avatar
The vtm 4 light is for the cv axles more than likely cause myine did the same and i replaced cv axle and it fixied tge problem
jeff gonzalez
10
06-27-2019 10:16 AM
aznoophi
02-21-2008 12:55 PM
DannyITR
07-21-2004 05:10 PM
champwhiteitr
03-17-2004 03:39 PM
yoshio006
12-17-2002 06:18 PM
Quick Reply: 04 pilot: possible EGR??? vtm-4 and check engine light on!
