K24 rod bearing question
Old 02-13-2011, 09:11 PM
JDM 98 GSR's Avatar
Default K24 rod bearing question
im building a k24a4/k20a2.. i have 06 TSX rods and 09 TSX pistons my question is which rod bearing do i use with my stock k24a4 crank?..im guessing TSX ones due to them being TSX rods but if so which thickness is safe to use?
Old 02-14-2011, 09:03 AM
JDM 98 GSR's Avatar
Default Re: K24 rod bearing question
20 views but no one knows?
Old 02-14-2011, 09:59 AM
m_shake's Avatar
Have you even tried looking at the service manual??? it's all in there.
Find the numbers on the rods and rod journals and match them to the oem bearing chart
Old 02-14-2011, 10:11 AM
JDM 98 GSR's Avatar
yeah but my question is for people that have done it usings the a4 crank..is it the same or not? i know i have to use tsx ones..my question was which thickness if safe with the a4 crank or if there is any difference
Old 02-14-2011, 03:52 PM
6SPD_EK's Avatar
I'd measure the clearances - preferably mic'd, if not then plasti-gage
there is no major difference between cranks
Old 02-15-2011, 08:41 AM
JDM 98 GSR's Avatar
i think i might just run ACL bearings
Old 02-15-2011, 03:11 PM
m_shake's Avatar
plasi-gauge AT THE LEAST!!!
Old 10-27-2011, 11:09 PM
Honda Type R's Avatar
I have a question to add to this post. I also have an A4 crank with A2 rods. Do I use A4 bearings or A2 bearings? My hard drive failed on my PC so I can't look at my manuals. So any help would be much appreciated!
jArceo
04-03-2011 03:01 PM
tico
01-04-2011 08:43 PM
boostedeg302
04-24-2008 08:17 AM
ppfalcon
06-21-2005 09:38 PM
KillerBee18
09-17-2003 08:53 PM
Quick Reply: K24 rod bearing question
