spun bearing, reuse the rods?
i have a quick question for you guys. it may be obvious but ive never dealt with a spun bearing. im looking to buy some eagle rods for pretty cheap but the guy says that one has a spun bearing. is the rod okay to use if i just replace the bearing with oversized ones or will it just pose problems in the future? again sorry for the noob question but i just wanna make sure before i drop some money on something that i wont be able to use. thanks
Re: spun bearing, reuse the rods? (boostedeg302)
take it to a machineshop, if its not black, overheated and stressed i would use it. i have done it before, but it wasnt overheated and black.
Modified by boostedcivicsir at 5:54 PM 4/23/2008
Re: spun bearing, reuse the rods? (blinx9900)
haha. ill post pics as soon as i get some. they seller says that two look questionable...but then again neither one of us are machinists
Man U FTW
Generally when a rod bearing spins, you end up ovaling the rod. This will cause you to continue to spin rod bearings in the future. Your best bet is to do 1 of 2 things.
1. Bring it to a machine shops and have them check it for oval...then line bore them if they are out-of-round. You will then need oversize bearings.
2. Buy a set of Eagle rods.
Modified by Schister66 at 4:27 PM 4/23/2008
Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 »</TD></TR><TR><TD CLASS="quote">i have a set of GSR Eagle rods sitting around</TD></TR></TABLE>
You're lucky CRX Toad isn't a mod here, he'd lock this thread and detuct 1%, despite being a mod yourself.
The rod is usually junk if the bearing spun in the rod. If it was just beat up/eaten away and the tangs kept the bearing in place, its fine if it didnt' overheat. If you can get the rods for 1/2 price, do so and buy a replacement rod. IIRC people have bought them for ~$80.
Man U FTW
Re: (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile »</TD></TR><TR><TD CLASS="quote">
You're lucky CRX Toad isn't a mod here, he'd lock this thread and detuct 1%,.</TD></TR></TABLE>
Edited out...
Edited out...
Mr. Badwrench
Re: (Schister66)
depending on the power leve, is wether i would reuse it.
hey adam, they can actually mill the cap down a little and resize the big end, w/o messing with the installed height too much.
but if you plan on spinning this engine and making decent power, i would just get a new rod, because now you are throwing out the balance, and theoretically weakening the big end on that rod.
if youre only looking at 1 rod, just get urself a rod. it less than a hundred bucks for eagles.
arc_55
06-28-2011 04:56 AM
boostedeg302
04-21-2008 11:40 AM
