what oil weight for an lsvtec swap??
Old 10-10-2007, 12:42 PM
dansred2000si's Avatar
Default what oil weight for an lsvtec swap??
I just bought an integra with an lsvtec swap and the seller told me to use 20w 50 on it for some reason. I always used 5w 30 on my b16 and was wondering why this guy told me to use a heavier weight??? any ideas?? should I stick to 5w30 or what oil should i use???
Old 10-10-2007, 02:43 PM
chakie jan's Avatar
Default Re: what oil weight for an lsvtec swap?? (dansred2000si)
if it has stock internals, i'd stick with 5w30, because it's what's recommended for gs-r's and ls's. i have no idea what you should use if it has aftermarket internals.
Old 10-10-2007, 04:16 PM
AllMotrLsv's Avatar
Default Re: what oil weight for an lsvtec swap?? (mrdeadly209)
I have a Lsvtec with internals and im not sure if its the best thing or not but im using 10w 30 and it runs fine...
Old 10-10-2007, 08:46 PM
chakie jan's Avatar
Default Re: what oil weight for an lsvtec swap?? (AllMotrLsv)
i believe 10w30 is fine as long as where you live doesn't get colder than below 20 degrees. i've used 10w30 since i've gotten my car (about 2 and a half years) and have had no problems. any weight besides 5w30 and 10w30 is beyond my knowledge though.
Old 10-10-2007, 10:15 PM
In My Built LS/Vtec I Run Mobile One 15-50 Allways.
Never had a problem, and never burn any oil between changes
Old 10-10-2007, 11:34 PM
well I am going to try out 5w 30 to see how that works out but i remember the seller telling me something about it being ported and polished and that is why the guy that built the motor told him to stick with 20w 50??
Old 10-11-2007, 08:50 AM
boostedh22lude1's Avatar
20 50 IS WAY TO THICK, YOUR OIL JOURNALS ARE DESIGHNED FOR 5-30 UNLESS YOU LIVE IS HIGH TEMPS. THEN MAX 10 40, THE 20 50 COULD STARVE YOUR ENGONE OF OIL.
Old 10-12-2007, 12:05 AM
I also noticed that the vtec does not kick in that hard compared to my old em1.could that be the flow of the oil?? maybe to thick to flow??
RSX_S
05-07-2008 11:58 PM
islnder102
10-12-2006 06:45 AM
Mike banX
10
05-17-2004 12:18 PM
Burke
07-07-2003 11:25 PM
1hotintegra
07-10-2002 03:39 PM
Quick Reply: what oil weight for an lsvtec swap??
