loose gas pedal after swap
Old 09-21-2002, 07:41 AM
Dorikamu's Avatar
Default loose gas pedal after swap
I have recently did a b18b swap, but it seems like the gas pedal loose...
it turns out the wire connects to gas pedal is too long..
can someone tell how they solve this problem, e.g. do I buy the wire from integra to switch it.. or do I have to have someone to cut the wire shorter...
Please give me some pointers..
Old 09-21-2002, 09:25 AM
New User
LshatchTurbo's Avatar
Default Re: loose gas pedal after swap (chusai)
Are you speaking of the throttle cable or a electrical wire?
Old 09-21-2002, 10:06 AM
Dorikamu's Avatar
Default Re: loose gas pedal after swap (lshatchturbo)
the throttle cable.. I think
it's the one if you put, it gives gas to the engine
Old 09-21-2002, 10:16 AM
Jonathan_ED3's Avatar
make the throttle cable taughter at the throttle cable bracket on the Intake Manifold.
If that doesn't do the trick, you'll have to go under the dash.
Does it idle fine?
Old 09-21-2002, 02:38 PM
Dorikamu's Avatar
Default Re: loose gas pedal after swap (hot_EG)
sometimes it doesent idle that well..
the RPM tends to go lower than 800..
I also have problem to start the car sometime, could this be related?
how do I tighten the throttle cable at the bracket?
Old 09-21-2002, 03:25 PM
New User
Did you use a civic throttle cable, or did you pick up a integra one when you did the swap?
Old 09-21-2002, 05:07 PM
Dorikamu's Avatar
I think I used the civic one, do I need a integra one?
Old 09-21-2002, 06:15 PM
Dorikamu's Avatar
someone help pls
Old 09-21-2002, 08:36 PM
New User
You could rig it with the civic cable, but from my personal experience I have never been able to use the civic cable properly. I always used the integra cable when I did swap with a gs-r and ls. In my car, I have a b18b1, back then I tried the civic cable, but it just couldnt get it to work right. But yea, the integra throttle cable will only run your $20 bucks from the dealer and should line up right.
truxvi3tz
03-31-2010 02:26 PM
r1chst3r
06-23-2008 03:14 PM
uncle
03-08-2005 06:06 PM
RACERX72
02-14-2005 10:04 AM
B2FiNiTY
11
12-02-2003 01:37 PM
Quick Reply: loose gas pedal after swap
