Overheating question
My h22 has been getting hot lately but only during idle. The temp is fine when i am driving. I only have one fan because i got rid of the other one when i removed the a/c. I was told it was alright. I don't think that has anything to do with it because it only had 1 fan for over a year and the problem just started happening now. What else would be causing it to overheat. I'm doing a coolant flush and replacing the thermostat today.
Re: Overheating question (eric416)
Yeah, I would say it is probably time for a new radiator. That thing looks like crap! No wonder you're overheating!
Re: Overheating question (slamdlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slamdlude »</TD></TR><TR><TD CLASS="quote">Yeah, I would say it is probably time for a new radiator. That thing looks like crap! No wonder you're overheating! </TD></TR></TABLE> x2 Good luck
is there a how to for bleeding the coolant for the h22 engine? I mostly work on nissans and know where to bleed the air from the coolant runs, but am not sure on the honda stuff.
does anybody know a link for where to bleed the coolant on the h22?
its on the thermostat housing, fill up the coolant with the bleeder valve open until it flow out, shut it, then start the car and bleed the air out, make sure your heat is on full blast during the whole process.
Yup, the bleed screw on the Thermostat housing. You can also remove the radiator cap and let the car idle which will disperse air bubbles.
Car doesn't need to be running, just pour coolant til a steady stream comes out of the bleeder screw.
I would replace your fan also and check your wiring to the fan and such, wires may be corroded...also look for cracked or frayed coolant lines...
