97 sh transmission base engine questions
Old 01-31-2010, 06:44 AM
Apocolipse269's Avatar
Default 97 sh transmission base engine questions
Hey just got my prelude and have few questions on replacing the engine. Hearing mixed answers on the question of the H22a4 BASE engine on the Type SH transmission, just want to clarify. Also, anyone in the MD/VA/PA/WV area have an h22a4 for sale....i can use one
Old 01-31-2010, 07:11 AM
Pearlwhitesh's Avatar
Default Re: 97 sh transmission base engine questions
it shouldn't work. you have to use the atts unit with it and have to use the sh block in order for it to hold the atts unit.
Old 01-31-2010, 07:42 AM
street_ride14's Avatar
yup, SH block and SH trans together .. you can not run one without the other. I'de go with the Base instead of the SH model as a personal preference, more room for power upgrades.
Old 01-31-2010, 10:06 AM
Hmm the guy i got the car from told me somethign about using a base engine and removing the atts unit, getting a new axle or some **** like that. I'm trying hard to find an SH engine for under $1000 :/ hard to do, cant spend more on base + tranny either :/
Old 02-05-2010, 09:04 AM
you can run a base tranny on an SH motor buy making a plate to bolt to the back of the block and using an halfshaft but you can't use and sh tranny on a base block.
Old 02-05-2010, 10:33 AM
Thanks for the answers, got an SH longblock off ebay, from a parts dealer (42000 rated, engine compression tested and leakdown tested), bought a whole bunch of gaskets for intake/exhaust manifolds, rear main seal, etc that i didnt already have, thinking about doing the whole manual tensioner thing too, what are the benefits of this?
Old 02-05-2010, 06:01 PM
jlude90's Avatar
Its less prone to failure, more peace of mind. On a stock engine driven stock-like its not that great of a worry. But I would recommend it, its definitely a better safe than sorry type of situation. A couple hundred bucks on the conversion versus a jacked up timing belt...you can do the math on that one.
I would also look into balance shaft removal.
Old 02-06-2010, 03:55 AM
Heh, accually the guy who owned the car before me put the manual tensioner on the engine, though that engine is bad now, and going to be replaced, can i use all of the parts from the old one to do the manual tensioner?? or are some/all new parts recommended
Old 03-15-2017, 05:57 PM
Mikeymikey023's Avatar
I found a sh engine for 900$
Okay one question, will an sh engine work with my base transmission? Been seeing a lot of mixed answers. Thanks
Old 03-16-2017, 06:02 AM
Moderator
snobordboy's Avatar
The engine will work fine, but you will need to fabricate something to support the intermediate shaft for the drivers side axle.
Old 03-16-2017, 07:01 PM
TimiK's Avatar
With Kaizenspeed h22 tensioner you only need one part - not like h23 manual tensioner swap and kaizen is reusable
So basicly thats "not directly" :D
Old 04-22-2017, 12:06 PM
Jorge Smith's Avatar
I have a base model engine with no issues trading for sh
UniqueX707
11-06-2014 04:01 AM
Apocolipse269
03-29-2011 05:01 AM
TCPRELUDE
11-05-2004 12:23 PM
black_sh
03-20-2003 05:08 PM
RedLude2
05-10-2002 09:47 AM
Quick Reply: 97 sh transmission base engine questions
