Question about replacing block on SH
Old May 9, 2002 | 10:18 AM
RedLude2's Avatar
Default Question about replacing block on SH
Hi,
Recently, my engine got messed up and need to build my engine again.
http://www.preludeonline.com/showthr...0&pagenumber=1
I have 97SH.
Anyway, I bought parts from here and there to rebuild my engine. And I bought block from base model. But I just found out that Base model and SH model blocks are not interchangable. So, since it's really hard to find a block, I want to keep the block. So, I guess I need base model tranny, but
do I need axles from base model too?
Thanks
Old May 9, 2002 | 12:13 PM
Quaalude's Avatar
Default Re: Question about replacing block on SH (RedLude2)
u should be able to use the axles...i think u need a or some halfshafts because the atts unit on the sh takes the place of one of the halfshafts....and u definitely need the base tranny...u can use the h23 tranny i think but this will give u longer gears...keep me informed about what parts u have to get for the sh to base swap because i have a h22a1 that i am going to build up and swap into my sh
Old May 10, 2002 | 09:47 AM
sgT's Avatar
sgT
Default Re: Question about replacing block on SH (Quaalude)
to put a regular h22a in place of the SH h22a, you will need a NON-SH transmission
as well as the intermediate shaft(if you need one, i have 2). The axles between
the two are listed as different lengths so I would go ahead and get the non SH
axles as well. Otherwise it should be straight forward.
Apocolipse269
Apr 22, 2017 12:06 PM
ludejaime
Jul 3, 2007 06:09 AM
aznpreludeSH
Feb 4, 2005 05:24 AM
TCPRELUDE
Nov 5, 2004 12:23 PM
connvict
Nov 3, 2004 11:38 AM
