1990 Civic CEL/ECU Problems?
Having some problems on my son's Civic. It's been over a 100 degrees here and the CEL has been coming on. If you check the LED on the ECU it's 1 lond flash and 16 short flashes. If you put a jumper wire in the 2 prong plug to check the stored code it does nothing. Also, it occasionally won't start. It will crank and crank but won't start. When it cools off outside the car starts fine. Please help! matt
DO IT ON ALL FOURS
Re: 1990 Civic CEL/ECU Problems?
On 88-91's the codes are checked via the LED on the ECU. The connector is only for setting ignition timing.
hmmm.. yeah he is right about he blinks try counting again.
I had a ef civic hatch back in high school that wouldnt start if it was hot outside, would just crank and crank
but if it was a cold early morning she fired right up but no codes.....never did figure that one out
Try replacing the PGMFI relay. My 1990 STD did the same thing when it was hot out sometimes I would drive to a store run in grab a soda come out and it wouldn't start, I replaced the relay and haven't had an issue since.
delmo777
10-17-2012 03:30 AM
drumminforev
19
10-06-2006 12:12 AM
91civicEX
12-12-2003 11:44 AM
