91 da start up issues??
Old Mar 26, 2012 | 04:49 AM
91integragsr's Avatar
Default 91 da start up issues??
Ok I have a 91 Da, I have spark and fuel and timing is correct but engine will only crank.. Won't start.. Checked every relay and fuse and changed my ecu to another pr4 too see if it was ecu and that's not it either
Old Mar 26, 2012 | 05:22 AM
el crapitan's Avatar
Default Re: 91 da start up issues??
checked codes?
Old Mar 26, 2012 | 06:30 AM
Ya there are no CEL codes nor light coming on.. I turn the key to on position and it turns everything on correctly.. MFR is working too and I get good pressure for fuel and good spark but motor won't start still..?? I changed ecu out for ***** and giggles and nope still nothing??
Old Mar 26, 2012 | 06:31 AM
Even when I do jumper trick to the green and brown clip too.
Old Mar 26, 2012 | 06:56 PM
to check codes on non-obd, there's an led on the ecu which flashes the code. you don't have to jump the service connector. the ecu's led will flash as soon as you turn the key to run
is that how you checked it?
Old Mar 26, 2012 | 08:16 PM
justharoble's Avatar
Yeah count how many flashes it has, I wasted a whole week not knowing it was different to check codes on the OBD0
toytroy
Sep 27, 2012 10:06 AM
johnwohl
17
Apr 6, 2009 05:58 AM
DA_9
Mar 11, 2008 03:17 PM
cessnapilot
May 27, 2007 02:17 PM
saxman
16
Aug 26, 2005 10:00 AM
