yes another O2 simulator question.(different from others that i have searched and found)
Old 02-10-2007, 11:55 AM
j-rome's Avatar
Default yes another O2 simulator question.(different from others that i have searched and found)
Well I have a check engine Light on for my auto 98 civic EX. I got the code read and the guy said it was for catalytic converter insufficiency. I had my sensors checked out and supposedly they are fine so it must be my catalytic converter. I read on here you can just do the spark plug Non-fouler trick from auto zone where it extends the sensor away from the direct flow of fumes for cheaper then the ebay ones. Now I have read on here that some will still gets a check engine light because now it will think its to rich/lean or to cold. I have read this but they were all for other cars. also i need the 18MM non-fouler right?
Will this spark plug non-fouler trick work on my car with no probs if it really is the cat? or will i get a light for something else?
thanks!
Modified by j-rome at 1:24 PM 2/10/2007
Old 02-13-2007, 04:29 PM
j-rome's Avatar
well since i did not get a answer i just bought ther $4 part. ill post if it works or if i get another code when i do it.
Old 02-13-2007, 05:25 PM
sicones's Avatar
Default Re: (j-rome)
GL with the fouler but your just masking a big problem that should be taken care of, replacement of the catalytic converter. If the inside of the cat keeps melting and falling apart it could just eventully get clogged and cause poor performance and more problems
Old 02-13-2007, 05:29 PM
Relic1's Avatar
remove existing cat, install resonator or test pipe. install anti-fouler and secondary O2 sensor. Drive with no CEL.
if the cat is dieing it will cause more problems that you are going to mask by installing the fouler with the cat in there.
Old 02-15-2007, 04:28 PM
j-rome's Avatar
i just bought a used cat with 80k on it and he said it dident turn on a light and it comes with a sensor so i should be good to go.
troybmm
17
12-06-2011 05:36 AM
Mr.EM1_EK
12
05-30-2007 08:53 PM
preluder22
10-01-2006 06:41 PM
dashskier540
05-21-2006 06:39 PM
willyboyK20
04-23-2006 02:39 AM
Quick Reply: yes another O2 simulator question.(different from others that i have searched and found)
