weird temp issue
Old 05-10-2010, 04:52 AM
shoklid's Avatar
Default weird temp issue
so everytime i hit vtec and mash on the gas the temp gauge goes to cold then if u push in the clutch to shift it will go up to normal temp , then hit gas again and temp will drop ? any help?
Old 05-10-2010, 08:13 AM
shoklid's Avatar
Default Re: weird temp issue
Old 05-10-2010, 08:16 AM
300whpej's Avatar
your thermostat may be on its way out. i can ride vtec on the highway and not see a change in temperature either way. do you have consistently hot heat?
Old 05-10-2010, 10:27 AM
shoklid's Avatar
the temp drops to zero basically. yes heat inside car is fine. well guess ill replace thermo and see whats up
Old 05-10-2010, 11:09 AM
D16SiHatch's Avatar
i would concur with the replacement of the t-stat. sounds like it's stuck open to me
Old 05-11-2010, 11:39 AM
shoklid's Avatar
yea i would thought the same except rad hose is hard so its not stuck but prolly on its way out
Old 05-11-2010, 01:21 PM
300whpej's Avatar
the radiator hose's should both be hot (not scalding) and squishy, if not you have a bad thermostat.
Old 05-14-2010, 08:30 AM
shoklid's Avatar
eddie7978
03-22-2018 08:33 AM
ek_silverback
12-22-2008 09:34 PM
E JAY 1
04-26-2008 10:02 AM
bumthology
11
12-11-2004 11:23 AM
92LudeSI
03-09-2004 07:02 PM
Quick Reply: weird temp issue
