ugh stripped bolt help
Old 11-23-2005, 01:10 PM
BROKE.eg's Avatar
Default ugh stripped bolt help
i need to get a stripped bolt out. Its the timing belt tensioner bolt.
any ideas
Old 11-23-2005, 01:16 PM
Slowboy!'s Avatar
HOLY **** thats got to suck, I know the tool, dont know what its called thougt, sorry... Its like this bolt with spiral edged to dig into the striped bolt and gets it off.
Curtis
Old 11-23-2005, 01:26 PM
alotawatts's Avatar
Default Re: ugh stripped bolt help (BROKE.eg)
Is it stripped or broken ?. Stripped means re-tap - maybe to next size. Broken = EZ-out..........not always ez. If enough is exposed you may be able to put a notch in it on one side/edge and unthread it by tapping it with a very small chisel. ?
Old 11-23-2005, 01:41 PM
BROKE.eg's Avatar
Default Re: ugh stripped bolt help (alotawatts)
the bolt head is stripped so i cant get the bolt out. i was thinkin of using one of those craftsman bolt exctractor kits but i dont know if that will work on something thats torqued down that much.
Old 11-23-2005, 01:55 PM
CiSmoEk4's Avatar
that sucks soo bad...i did the same exact thing..i just used one of those little grinders with a 3" disc and grinded the head of the bolt off and i was able to get the plastic timing belt cover off..and then i got vise grips and turned it and i tcam off pretty easily. go buy a new one from honda and you're good. be careful not to grind into the tensioner itself!! this way worked for me.
Old 11-23-2005, 02:27 PM
peacexisxfree's Avatar
Default Re: (CiSmoEk4)
had the same thing happen to me on my 71 mustang. try an e-z out. just go buy a set. i guarantee you will use at least 1 again in the future.
Old 11-24-2005, 06:59 AM
BROKE.eg's Avatar
Default Re: (peacexisxfree)
anyone used the craftsmanbolt extracor like this one with any luck?
http://www.sears.com/sr/javasr...CRAFT
Old 11-24-2005, 07:00 AM
xEnderx's Avatar
Default Re: (BROKE.eg)
You've got to be really careful and patient the first time you use extractors or bolt-outs. They can **** you off, but if you use them correctly they DO work.
Old 11-24-2005, 07:30 AM
BROKE.eg's Avatar
Default Re: (xEnderx)
i like the extractors better cause you dont have to drill anything.
Old 11-24-2005, 07:38 AM
spoonracer84eg's Avatar
This is my craftsman bolt out set. It works great. Cost me about $50 to $60. Great investment though. Fits 10mm to 19mm. They have other sets also.
Old 11-24-2005, 07:41 AM
snowman0520's Avatar
thats what i used to get my belt tensioner bolt out and it was striped pretty bad
Old 11-24-2005, 08:02 AM
BROKE.eg's Avatar
cool, looks like ill be pickin one up tomorrow when sears is open.
Old 11-24-2005, 08:03 AM
pdiggitydogg's Avatar
those things never work for me
Old 11-24-2005, 08:10 AM
Keith Pierson's bitch's Avatar
i'll vouch for the boltouts... i had a rounded off head bolt... down in the hole and everything sucked ***.... i went ot my work and borrowed the boltout... these were Snap On though... but it worked like a champ. Just gotta pake sure they are all the way down on the head of the bolt
Old 11-24-2005, 08:32 AM
Default Re: ugh stripped bolt help (xxturbodreamsxx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxturbodreamsxx &raquo;</TD></TR><TR><TD CLASS="quote">i'll vouch for the boltouts... i had a rounded off head bolt... down in the hole and everything sucked ***.... i went ot my work and borrowed the boltout... these were Snap On though... but it worked like a champ. Just gotta pake sure they are all the way down on the head of the bolt </TD></TR></TABLE>
The instructions say to get the size that fits just onto the head of the bolt. Doing so allows the bolt out to dig down into the metal. Thats how it works. You will need to replace the bolt.
Old 11-24-2005, 08:53 AM
Default Re: ugh stripped bolt help (spoonracer84eg)
well it fit just on the head of the bolt but sometimes it doesnt wanna grab, so you have to make it grab, either way the bolt came out fine
Old 11-24-2005, 09:26 AM
.Ry
.Ry's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BROKE.eg &raquo;</TD></TR><TR><TD CLASS="quote">cool, looks like ill be pickin one up tomorrow when sears is open.</TD></TR></TABLE> They are like halfoff tommorow for Black Friday, Im gettin my set then to. But I get my associate discount
Old 11-25-2005, 08:19 PM
BROKE.eg's Avatar
Default Re: ugh stripped bolt help (turner7205)
i picked up that craftsman bolt extractor pictured above it worked perfectly. awsome tool.
clindberg86
29
06-26-2014 08:51 AM
psychotech
10-15-2010 11:56 AM
dephtone
12-01-2008 06:59 AM
Schrader
04-25-2006 02:23 PM
Hoosier Daddy
10-11-2003 02:04 AM
Quick Reply: ugh stripped bolt help
