Transmission Removal
Old 12-22-2003, 02:22 PM
jovial111's Avatar
Default Transmission Removal
I have a few questions regarding the tranny removal to replace the clutch.
1. How many 17mm bolts must you remove from the tranny to the block?
2. Do you have to remove the rear engine mount?
3. If so then why?
4. Some manuals (b16a w/ cable tranny) say to remove the distributer...do I have to do this?
5. Do you have to remove the intermediate shaft?
Car is a 93 civic w/ b18c1
Old 12-22-2003, 02:24 PM
Atheist's Avatar
2. IIRC there is a bolt going from the mount to the tranny, just pop that out (not 100% sure)
4. I didnt have to
I just took off the starter, bolts, mounts, and axles. Popped right out! This was a dseries, though
Old 12-22-2003, 02:31 PM
Down Since Day 1
1 point 6's Avatar
Default Re: Transmission Removal (jovial111)
1. How many 17mm bolts must you remove from the tranny to the block? I think there is about 10, dont forget the starter bolts!
2. Do you have to remove the rear engine mount? I believe this is a negative.
4. Some manuals (b16a w/ cable tranny) say to remove the distributer...do I have to do this? Never heard of that or done that from personal experience.
5. Do you have to remove the intermediate shaft? I just take off the 32mm axel nut, take off the control arm castle nut and pull the whole axel out and set it out of the way.
Old 12-22-2003, 03:55 PM
cxSHOE's Avatar
Default Re: Transmission Removal (1 point 6)
get the manual in my sig... and remember to remove the starter also....
Old 12-22-2003, 08:23 PM
jovial111's Avatar
Default Re: Transmission Removal (cxSHOE)
thanks...
this tranny removal is a biatch
96GS-R-Kaden
11-05-2007 04:01 PM
TEGGRY
06-23-2006 05:59 AM
coot_er
12-24-2005 03:46 AM
IMSTOCK
12-02-2005 04:46 PM
jovial111
12-22-2003 02:30 PM
Quick Reply: Transmission Removal
