Squeaky noise from coming the transmission when i step in the clutch
Old 11-16-2010, 04:09 PM
JDMpride's Avatar
Default Squeaky noise from coming the transmission when i step in the clutch
squeaky noise coming from the transmission when i step in the clutch when the car is off or on...help
Old 11-16-2010, 04:14 PM
Former User's Avatar
Default Re: Squeaky noise from coming the transmission when i step in the clutch
Sounds like a bad clutch throw out/release bearing.
Old 11-16-2010, 04:30 PM
Seagull Management
94EG8's Avatar
If it was only doing it when the car was running i'd agree with you. But its doing it with the car off as well. I'd lube up the pivot point where the slave cylinder pushes on the release fork with some high temp grease first and see what that does.
Old 11-16-2010, 04:32 PM
Yep, I missed the off part.
Old 11-16-2010, 04:35 PM
hybrid1990crx's Avatar
You need to oil the pivot point of the clutch fork.
Old 11-16-2010, 04:37 PM
andyek4's Avatar
as above! really annoying when you dont have a stereo!
JDMpride's Avatar
this is how it sounds
http://www.youtube.com/watch?v=PNfp83Od_c4
Old 11-16-2010, 04:38 PM
JDMpride's Avatar
how do u do that
Old 11-16-2010, 04:48 PM
JDMpride's Avatar
u guys think that this can fix the problem....i dont think so... i thinks that the problem is in the inside
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/diy-fix-squeaky-clutch-2673423/
Old 11-16-2010, 04:58 PM
JDMpride's Avatar
this 1 too
http://www.civicforums.com/forums/7-...pic-added.html
Old 11-16-2010, 05:03 PM
JDMpride's Avatar
http://www.s2ki.com/forums/index.php?showtopic=370792
Old 11-16-2010, 05:24 PM
BigBlock22's Avatar
it sounds dry, you can try pulling the boot off and lubricating the shaft. it most likely needs some grease between the ball end of the slave cylinder shaft and shifter fork
Old 11-16-2010, 06:18 PM
blakevarian's Avatar
Remove the slave cylnder from the trans and preas on the clutch if it still makes the noise then u need a new slave cylnder if not it could be the diaphragm springs on your clutch or where the throw out bearinf slides back and fourth on the input shaft u are supost to use hight temp grease wheere the throw out bearing rides on tje input shaft. But it sounds like the s/c to me
Old 11-18-2010, 08:10 AM
snake_eyes's Avatar
lmao that is one funny video!
Nick Kozeski
09-02-2015 02:18 PM
victor.m
04-04-2009 09:19 PM
kmksub
Honda Civic (2001 - 2005)
11-12-2007 12:07 PM
RemerLex11
03-30-2005 10:10 AM
The Internet Tough Guy
09-26-2003 10:23 PM
Quick Reply: Squeaky noise from coming the transmission when i step in the clutch
