Rear main seal!!!!!
Old 01-01-2006, 08:28 PM
JDMPower98cp's Avatar
Default Rear main seal!!!!!
Ok so my car is leaking oil in between the motor and tranny im guessing its the rear main seal!!! ouch any suggestions and on how to do it.. The car is a 98 honda civic HX d16y5..anything would help thnx..
Old 01-01-2006, 08:30 PM
coquitlamEG's Avatar
Default Re: Rear main seal!!!!! (JDMPower98cp)
Only one way to do it. Take the engine out, remove the flywheel and change the seal.
Old 01-01-2006, 08:41 PM
Default Re: Rear main seal!!!!! (coquitlamEG)
i was thinking abt removing the tranny then the clutch and flywheel...does it require any internal work or is it on the outside????
Old 01-01-2006, 09:15 PM
Luserkid's Avatar
You dont need to pull the whole motor to get it.
Remove tranny
Remove clutch
Remove flywheel
Remove oil pan
Remove rear main seal
Replace RMS
Put back oil pan
Put back Flywhel
Put back clutch
Put back tranny
Have a beer.
If its your first time have a weekend set aside to do it.
Old 01-02-2006, 12:11 AM
Earthworm Jim's Avatar
Default Re: Rear main seal!!!!! (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">You dont need to pull the whole motor to get it.
Remove tranny
Remove clutch
Remove flywheel
Remove oil pan
Replace RMS
Put back oil pan
Put back Flywhel
Put back clutch
Put back tranny
Have a beer.
If its your first time have a weekend set aside to do it. </TD></TR></TABLE>
All of that is a pain in the rump but it's needed
89bluehatch
03-03-2007 12:53 PM
Ricey McRicerton
09-17-2005 09:53 PM
Do_Ster
01-14-2005 08:23 AM
0ptimus prime
12
07-18-2004 01:29 PM
Lei Siew Long
08-19-2001 05:35 PM
Quick Reply: Rear main seal!!!!!
