Radio problems.need help
Old 08-01-2009, 10:29 PM
New User
thorgy's Avatar
Icon6 Radio problems.need help
I'm having some trouble installing a radio I got for my 2000 honda civic dx.I hooked up each wire from the car to the radio correctly and every time I hook the radio up my radio fuse pops.Someone said it could be a short but is there specifically a wire that would short out? Could it be the radio itself? the display still comes on the radio but it says have a nice day and shuts off.Please I need help I haven't had a radio in a long time.
Old 08-01-2009, 10:35 PM
StayKrafty's Avatar
Default Re: Radio problems.need help
There's an audio forum for this. But, are all the wires hooked correctly. It sounds like somethings shorting for sure. Have you checked all the wires and made sure nothing was touching?
Old 08-01-2009, 10:39 PM
New User
thorgy's Avatar
Oh sorry didn't know about the audio forum.Yeah I made sure none of the wires were touching and it still blows the radio fuse.I don't get it.
Old 08-01-2009, 10:43 PM
StayKrafty's Avatar
Sounds like its not grounded correctly. Check the ground, try changing it. This happened in my talon quite a bit.
Old 08-01-2009, 10:46 PM
New User
thorgy's Avatar
thanks.any recommendations on where to ground it.
Old 08-01-2009, 10:47 PM
StayKrafty's Avatar
Just anything metal really. I ran a ground from under my dash to the radio just to insure it was grounded good.
Old 08-01-2009, 10:52 PM
New User
thorgy's Avatar
On the harness going from my car there is a black ground wire and a black ground wire coming from the radio so wouldn't i splice the two together for the ground?
Old 08-01-2009, 10:54 PM
StayKrafty's Avatar
Yeah, is it not already spliced together?
Old 08-01-2009, 10:56 PM
New User
thorgy's Avatar
It is spliced together really good.That's what I don't get
Old 08-01-2009, 10:58 PM
StayKrafty's Avatar
Is the yellow wire connected? Along with the red? Red is battery and yellow is constant.
Old 08-01-2009, 11:00 PM
New User
thorgy's Avatar
Yup its all connected really good.
Old 08-01-2009, 11:02 PM
StayKrafty's Avatar
Well its one of the 3 for sure. Somethings shorting. Sounds more like a ground issue. I would change that first and go from there. If its turning out, I wouldn't think its battery related. Same with the constant power. I'd put my money on the ground.
Old 08-01-2009, 11:07 PM
New User
thorgy's Avatar
ok thanks a bunch man
Old 08-01-2009, 11:14 PM
StayKrafty's Avatar
Not a problem man. Post back if it doesn't work. Also, check and make sure its the correct fuse. I've seen many fuses blow because they weren't the correct size.
Old 08-02-2009, 03:04 AM
MHDesigns's Avatar
One thing that is almost always overlooked when installing stereo equipment is a proper ground. You can't just stick it to metal. 99% of the metal on the car has some sore of coating on it for corrosion resistance. You must always sand the spot for the ground down to ensure a proper connection.
Radios are simple. Power, Ground, then pos/neg speaker wires. And a fuse. Check all connections for exposed/touching wires. Check your power and make sure fuse is proper. If all of this appears to be intact but you still have issues, check it again because thats all it could be.
MUGEN_EG95
Acura TL, RL & ZDX
10-13-2009 06:26 PM
vteckyle
07-31-2007 12:41 PM
compprat
05-31-2006 09:38 AM
91SiRX
05-27-2005 01:02 PM
vxnine
12-01-2003 06:47 PM
Quick Reply: Radio problems.need help
