quick questions d16z6's have how many o2 sensors
Old 07-26-2004, 06:30 PM
Gant's Avatar
Default quick questions d16z6's have how many o2 sensors
im converting to obd1
so far i have a
d16z6/si trans
vtec controller
p28 ecu
clutch
and have the obd1 harness on the way
the shop im going thru has the motor and its not open right now he told me to get a o2 for the motor, but how many they have? do i need to grab 2? or jsut one?
Old 07-26-2004, 07:04 PM
Gant's Avatar
ttt
Old 07-26-2004, 07:06 PM
ironcheftony's Avatar
just one
Old 07-26-2004, 07:31 PM
Dyzee's Avatar
Old 07-26-2004, 07:41 PM
Gant's Avatar
Default Re: (Dyzee)
thanx guys i appreciate it
where do u think i should get the o2 sensor at?
i work at a dealership and i get discounts when ordering from other dealerships are OEM o2's expensive?
or shoudl i just go to kragen/autozone?
Old 07-26-2004, 07:43 PM
mjrage's Avatar
Default Re: (Ba4)
there have been some talk that those az ones arent worth it. People throwing codes even after. I'd just buy one from the dealer but thats me.
Old 07-26-2004, 07:45 PM
ABK
ABK's Avatar
Default Re: (mjrage)
1 o2 which is 4 wire. Why are you getting obdI harness and why are you getting vtec controler?
Just get a obd o>obdI jumper harness, and run a p28
and why are you getting EG tranny? it's hydrolic!!! You need cable so look for a crx SI, or EF SI tranny.
Old 07-26-2004, 07:55 PM
FERIOkid's Avatar
Default Re: (ABK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK &raquo;</TD></TR><TR><TD CLASS="quote">1 o2 which is 4 wire. Why are you getting obdI harness and why are you getting vtec controler?
Just get a obd o&gt;obdI jumper harness, and run a p28
and why are you getting EG tranny? it's hydrolic!!! You need cable so look for a crx SI, or EF SI tranny.</TD></TR></TABLE>
thats what i was thinking ^^
Old 07-26-2004, 08:05 PM
Gant's Avatar
Default Re: (slowdx9585)
did i say i have a hydralic no omfg, its a SI transmission from a crx
and its not a whole obd 1 harness
its a conversion harness obd0-obd1 from boomslang please next time u try and act smart try harder u idiot
and why a vtec controller , for future purpose's i got one so when i tune it i know where the optimal point is
Old 07-26-2004, 08:21 PM
ABK
ABK's Avatar
Default Re: (Ba4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ba4 &raquo;</TD></TR><TR><TD CLASS="quote">and why a vtec controller , for future purpose's i got one so when i tune it i know where the optimal point is</TD></TR></TABLE>
$300 for the wild guess, you won't know the optimal point without a dyno, each engine is slightly different, and without serious mods stock point is the best. You crossover too soon your run out of power, you cross over too late you loose mid.
Old 07-26-2004, 08:29 PM
Gant's Avatar
Default Re: (ABK)
when i said tune it i meant on the dyno :/ come on now, im not going to just set it low and then call it quits
i should specify things more specially in my orginal post because we got alot of jackass's trying to be smart
Old 07-26-2004, 08:36 PM
ABK
ABK's Avatar
Default Re: (Ba4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ba4 &raquo;</TD></TR><TR><TD CLASS="quote">when i said tune it i meant on the dyno :/ come on now, im not going to just set it low and then call it quits
i should specify things more specially in my orginal post because we got alot of jackass's trying to be smart </TD></TR></TABLE>
I'm not tryign to be smart, I'm just trying to keep you from doing what's wrong. BTW did you ever look at uberdata, alot better and somewhat cheaper tuning tool?
$300 of vafc is a waste on stock motor internally
ThA IntegrA HI
10
10-12-2008 02:05 PM
boosted97civic
03-19-2007 04:32 PM
redvtec00
14
02-04-2007 04:52 PM
mjrage
23
08-16-2004 10:12 AM
Usdm1
12-16-2003 06:12 PM
Quick Reply: quick questions d16z6's have how many o2 sensors
