O-2 sensor needed for MAP SENSOR to work ??????????
Old 03-03-2007, 03:50 PM
D15JDMARIO's Avatar
Default O-2 sensor needed for MAP SENSOR to work ??????????
Old 03-03-2007, 03:59 PM
HT White Ops
Eran's Avatar
O2 sensor measures exhaust gases in the exhaust manifold, and MAP measures the pressure in the intake manifold.
I have no idea if they are systematically connected, but I wouldn't imagine so, considering they have completely different function.
Old 03-03-2007, 06:03 PM
D15JDMARIO's Avatar
Default Re: (Eran)
Im.. just wondering if you might help me with my issue?.. I just finshed installing a EX harness i got a 1995 civic DX.. Coupe with a jdm 1.5 Vtec.. im having problems with the map sensor. ive put 3 different sensor out of my friend cars that run.. with no problems.. and i have the p28.. the O2 sensor code 41. and the Code 3 witch is map sensor.. i dont know what else to do plz help!!!
Old 03-03-2007, 07:39 PM
APCforthewin's Avatar
Default Re: (D15JDMARIO)
Your Map will work w/o the O2 sensor BUT those sensors DO work together. The computer needs to know when your stepping on the gas(map value increases with mani vacuum decrease) and your O2 values should change with that. it needs to have both inputs for fuel trim changes.
PS remember that your Heated O2 sensor(first sensor) only measures the amount of oxygen in the exhaust, nothing else. the second O2 sensor ONLY measures the efficiency
of your cat converter.
riddlinkid1986
08-10-2008 04:43 PM
Btothe3rdDegree
08-28-2004 05:46 PM
Hoodwinked
12-01-2003 12:13 PM
pinoyboy204
11-02-2003 07:06 PM
SIK IN DA HED
11-15-2002 10:59 AM
Quick Reply: O-2 sensor needed for MAP SENSOR to work ??????????
