NEED HELP....CLUTCH PEDAL WONT RAISE UP
Old 10-16-2005, 09:45 AM
malubawla's Avatar
Default NEED HELP....CLUTCH PEDAL WONT RAISE UP
MY CLUTCH PEDAL DONT LIFT UP.........COULD IT BE THE CLUTCH MASTER CYLINDER OR NEED A NEW CLUTCH KIT??
Old 10-16-2005, 09:49 AM
sbcs15's Avatar
Default Re: NEED HELP....CLUTCH PEDAL WONT RAISE UP (malubawla)
it is possible that youmight just have a leak in the hydraulic system, check the fluid and check for leaks, you can also try bleeding it, that might help
Need more info to diagnose
Old 10-16-2005, 11:30 AM
92ehatch's Avatar
Default Re: NEED HELP....CLUTCH PEDAL WONT RAISE UP (sbcs15)
please take off caps
my sisters civic had same problem it was the master cylinder
Old 10-16-2005, 03:28 PM
* B A N N E D *
EGmikeH22's Avatar
First check the clutch fluid reservir, fill it if it isnt (to the full line).
If you don't have a clutch fluid reservoir, you have a cable clutch, and the cable is probably broken.
Next lift the clutch, then push it back down, see if doing this several times creates pressure.
Now go under your hood and check for fluid leaks from your clutch master cylinder (where the clutch fluid reservoir is mounted) all the way down the line to the slave cylinder (mounted on the front of your transmission).
If there is no fluid leaking, you probably have a blown master cylinder.
If fluid is leaking from the line between the master and slave cylinder, replace that section of line.
If fluid is leaking from the master or slave cylinder, the one that is leaking is blown.
Hope this helps.
Old 10-16-2005, 04:16 PM
tallyturbo's Avatar
i had this same problem about a year ago. my clutch master cylinder was shot.
Civic Racer X 7
11
08-27-2014 05:53 PM
Jaydeep
12-01-2011 05:35 AM
Gomdohree
04-24-2008 06:20 AM
The Droogan Leader
10-06-2006 12:05 PM
suavea82
05-20-2003 01:27 PM
Quick Reply: NEED HELP....CLUTCH PEDAL WONT RAISE UP
