Mains and rods torque specs. Please help.
Old 02-13-2004, 06:26 PM
yellow_jacket's Avatar
Default Mains and rods torque specs. Please help.
I need the torque specs for the mains and the connecting rods on a 96 Civic DX(d16y7) Thanks for the help!
Old 02-13-2004, 06:31 PM
infinatenexus's Avatar
Default Re: Mains and rods torque specs. Please help. (yellow_jacket)
Torque Specs
Camshaft Holder 8mm Bolts.....14-15ft lbs
Camshaft Holder 6mm Bolts.....104 inch lbs
Camshaft Pulley Bolt.......27ft lbs
AEM Cam Gear Adjustment Bolts(3 of them)....15ft lbs..apply Loctite "red" to the three retaining bolts
Connecting Rod Nut........23ft lbs
Crankshaft Pulley Bolt.....119ft lbs(D16A6).....134ft lbs(D16Z6)
Cylinder Head Bolts for D16A6
step 1.......22ft lbs
step 2.......48ft lbs
Cylinder Head Bolts for D16Z6
Step 1....22ft lbs
Step 2....53ft lbs
Cylinder Head Bolts for D16Y8
step 1(bolts 1-10)....15ft lbs
step 2(bolts 1-10)....36ft lbs
step 3(bolts 1-10)....49ft lbs
step 4(bolts 1 & 2)....49ft lbs
Cylinder Heads ...All D ARP Studs
Step 1......15ft lbs
Step 2......30ft lbs
Step 3......62ft lbs
Distributor Mount Bolt....17-18ft lbs
Flywheel Bolt........87ft lbs
Intake Manifold to Cylinder Head Nut..16ft lbs
Main Bearing Cap Bolt........47ft lbs(D16A6)..........Step 1...18ft lbs(D16Z6 and Y8)
Step 2...38ft lbs(D16Z6 and Y8)
Rocker Arm..D16A6
End Rocker Arm Shaft Cap..9ft lbs
All Others and all D16Z and Y8s..........16ft lbs
Throttle Body Nut.......14-16ft lbs
Timing Belt Adjuster Bolt.....33ft lbs
Valve Adjustment Nut....10ft lbs(D16A6)....14-15ft lbs(D16Z6 and Y8)
Old 02-14-2004, 05:32 AM
Default Re: Mains and rods torque specs. Please help. (infinatenexus)
I really appreciate it!
Old 02-14-2004, 05:50 PM
Not a problem
keithmay
02-01-2018 07:57 AM
hondaguy32
03-25-2011 10:58 AM
D-Man
12-24-2008 04:12 PM
B20vtec85
04-10-2007 03:21 PM
CiViCgT32
11-17-2006 07:13 PM
Quick Reply: Mains and rods torque specs. Please help.
