low compression in one cyl...what does that mean?
Old 07-19-2004, 02:58 PM
hondaeg8's Avatar
Default low compression in one cyl...what does that mean?
motor is a usdm b18c5 motor
compression was as follows:
cyl 1 -210
2 -125
3 -210
4 -210
as you can see, the compression for cyl 2 was very low compared to the other 3. i put in a cap of oil and checked the compression for that cyl again. it went up to 210.
the car still gets up and goes and pulls still. i have no oil light on, no check engine light on either. i no signs of a blown headgasket and i have no oil on the spark plugs.
could a bent valve have anything to do with that cyl being low on the compression?
the car was running fine and doing good. i just did a compression test to see what the numbers would look like and thats how they turned up.
any ideas?
Old 07-19-2004, 03:00 PM
Solbros Owns Me
Evs-One's Avatar
Default Re: low compression in one cyl...what does that mean? (hondaeg8)
most likely rings
Old 07-19-2004, 03:07 PM
hondaeg8's Avatar
Default Re: low compression in one cyl...what does that mean? (Emerika)
i thought if the rings were going bad, i would have oil on my plugs and smoke coming out the exhaust, i have neither.
Old 07-19-2004, 07:15 PM
smokinsi's Avatar
Most likely your rings are just fine.
However, your ring lands are cracked. You wont get any smoke just an off sound in the exhaust and shitty compression until you add oil.
The bent valve wouldn't change the compression when the oil was added. The problem is where the oil is making contact. Ringlands.
Old 07-19-2004, 07:18 PM
Master23's Avatar
Nope, the rods are bent. If it was then the car would have some serious starting and problems and it just wouldn't run.
Old 07-19-2004, 08:21 PM
hondaeg8's Avatar
Default Re: low compression in one cyl...what does that mean? (Jgears)
the rods are bent?
the car starts just fine.
Old 07-19-2004, 08:26 PM
1320DRAGWORKX's Avatar
IS YOUR RINGS I BET YOU THROUGH BLACK SMOKE ONLY AT HIGH RPM, THAT'S THE PROBLE CAUSE IT HAPPEND TO ME BACK IN THE DAYS...
Old 07-19-2004, 08:34 PM
hondaeg8's Avatar
Default Re: low compression in one cyl...what does that mean? (1320DRAGWORKX)
yeah...the car threw black smoke, but that because the ecu is a kenji chipped ecu.
Old 07-20-2004, 04:20 PM
smokinsi's Avatar
Don't know about bent rods. But, I cracked 2 ringlands on the #3 the car ran and started fine. Like I said the only thing was the Idle sounded off, more like a WRX rather than a civic.
The only difference was mine was 210 205 90 210
with a cap of oil added 210 205 225 210
Old 07-25-2004, 11:06 AM
IH82LOSE's Avatar
Default Re: low compression in one cyl...what does that mean? (smokinsi)
so how would the car sound if it had a bent valve
Old 07-25-2004, 11:13 AM
Evil_Wizard's Avatar
Default Re: low compression in one cyl...what does that mean? (IH82LOSE)
Like this Ka-chunka-Eeek-bhuuuuuh-vroom
doublezerohatch
07-01-2013 08:03 AM
skata89
12-21-2007 11:13 AM
95greenlude
11-03-2007 04:21 PM
JDMtype Eg6
07-14-2007 02:31 AM
Quick Reply: low compression in one cyl...what does that mean?
