help..P0135(O2 heater CKT Bank#1, Senr.#1) cel code
Old 04-17-2008, 01:00 PM
HAZARD_1310's Avatar
Default help..P0135(O2 heater CKT Bank#1, Senr.#1) cel code
I got a 99' civic ex, I already chaged the O2 sensor and ereased the code but keeps coming back could it be my catalyc converter? What else can it be?
Old 04-17-2008, 01:08 PM
junkspeedproject's Avatar
Default Re: help..P0135(O2 heater CKT Bank#1, Senr.#1) cel code (HAZARD_1310)
damnit. i have the same problem(P0141) in my 99dx, but for the downstream sensor (after the cat). the CEL for yours is indicating the primary sensor before the cat so your cat should still be fine. i got the same result after replacing my sensor with a new denso unit. i think the problem is with the wires between the sensor and the ecu. funny thing is, right before i went to smog, i unplugged my ecu to reset it, and the light stayed off. did my drive cycle and passed smog with flying colors.....parked the car overnight....then BAM stupid CEL is back.
Old 04-17-2008, 02:10 PM
Default Re: help..P0135(O2 heater CKT Bank#1, Senr.#1) cel code (junkspeedproject)
yeah..i tried that but mine comes back like 1 min. after driving.....I need to fix this to pass the smog too.... u think the wiring for the new sensor is wrong wrong and thats why its throwing that code any I ideas on what else cauld it be? or is this the only thing it could be? This Sucks.
Old 04-17-2008, 02:19 PM
thesmogman's Avatar
Not sure but I'm shooting from the hip because I don't have an OBDII car so here it goes..
Are there fuses for the heater circuts I know they draw a few amps. Might it have blown a fuse?
You can also try and swap your pre-cat sensor with the post-cat one to see if the code follow's the sensor.
A couple for you to check.
EDIT: I will get more info tomorrow.
Modified by thesmogman at 5:05 PM 4/17/2008
Old 04-23-2008, 05:29 PM
Default Re: help..P0135(O2 heater CKT Bank#1, Senr.#1) cel code (thesmogman)
I'll check this out tommorow morning thanks...
jdmBOMEXsi
04-25-2005 10:56 AM
GSRBoi785
09-04-2004 07:55 PM
N1NjA TuRtLE
12
06-05-2004 08:30 PM
Nocide_Eluded
05-24-2004 06:12 PM
Quick Reply: help..P0135(O2 heater CKT Bank#1, Senr.#1) cel code
