Water pump selection issues
Old 01-10-2011, 05:45 AM
brharris777's Avatar
Default Water pump selection issues
OK so im pretty new to the site and new to Hondas but I am certainly not new to cars. I am in the processes of Rebuilding a 1992 hatchback that had a cracked block, long story short its turboed and has an eagle stroker crank, eagle connecting rods and the name on the pistons slips my mind currently, I am in the process of putting the new B18C back together for it and happened to look at the water pumps i had from all the various bits and pieces i bought to get it put back together, and i noticed one of the 3 pumps has a slightly smaller pulley on it, i didn't count the teeth but i am definately saure it has less, I guess my main question is should i clean and use the pump with the smaller pulley, or use the brand new one with the larger pulley?
Old 01-10-2011, 06:57 AM
Default Re: Water pump selection issues
bump
Old 01-10-2011, 11:07 AM
blowededup's Avatar
I would go with a stock waterpump IMO.
Old 01-10-2011, 11:49 AM
94dxcoupe's Avatar
the smaller pulley one is an LS and must be used with an LS timing belt. Use the larger
Old 01-10-2011, 01:22 PM
ok thank you guys, so when i go to buy a timing belt what car should i tell them im buying it for?
Old 01-11-2011, 04:45 PM
bump
Old 01-11-2011, 07:09 PM
NotAJDMFanBoy's Avatar
Use a new GSR/B16 one. You need the one for the VTEC motor so that you don't get cavitation.
Old 01-12-2011, 12:37 AM
i already got the water pump, i need to know if the timing belt i get is going to matter, its a B18c non vtec.
Old 01-12-2011, 12:51 AM
MERC6372's Avatar
bump
Old 01-12-2011, 05:55 AM
Seagull Management
94EG8's Avatar
B18Cs are all vtec
Old 01-12-2011, 09:18 PM
Its a B18 C block with a B18 non Vtec head.
metroya_performance
09-17-2007 05:21 PM
beoy9
08-28-2006 06:05 PM
si_hatch
12-20-2004 04:00 PM
Project_ED8
03-22-2004 01:37 PM
Hondasaurs
07-30-2003 09:12 PM
Quick Reply: Water pump selection issues
