distributor O-rings/ is a O-ring, a O-ring?
Old 08-29-2013, 03:32 PM
redm3turbo's Avatar
Default distributor O-rings/ is a O-ring, a O-ring?
got my distributor off....to replace the O-ring b/c shes leaking and its smoking when the oil drips on the Hot engine. Anyhow...Its a bit late, the closest auto part store is a good 30 minute drive away- and I got the distributor off---the O-ring is absolutely shot (Then again its probably 15 years old at best) so it did perform an amazing job all things considering.
Anyhow, In my tool box I have O-rings from a hardware store (meant for plumbing) however I have an assortment..and have a perfect match---
So, I can't imagine there is a huge quality difference from auto grade rubber o-rings to plumbing grade rubber o-rings. I dont want to seem cheap, Im honestly asking if anyone knows if there is a difference. I'd honestly rather put the car back together if I can, I could care less about the couple dollars it'll save, I would love to save a trip and the time here. Id also much prefer not redo doing the o-ring in 3 days b/c this one turned to dust.
So anyhow, anyone know.
Old 08-29-2013, 04:14 PM
92lxsleeper's Avatar
Default Re: distributor O-rings/ is a O-ring, a O-ring?
is it the o ring, or the oil seal on the inside of the distributor? they are different.
Old 08-29-2013, 04:51 PM
redm3turbo's Avatar
^ outside... o-ring
Old 08-29-2013, 05:18 PM
EJ8mike's Avatar
If its the exact size, i dont see why it wouldnt work....make sure it seals tight around that shaft
Old 08-29-2013, 06:29 PM
94kreation's Avatar
Any o-ring is fine. Ive used some from the hardware store without any issues you should be good.
themiz816
04-28-2013 07:16 PM
ribal_gh
11-10-2012 10:00 AM
blacktibby07
11
02-05-2011 03:12 PM
210southstar
10-02-2009 03:59 PM
WVhump
Acura TL, RL & ZDX
03-28-2007 10:30 PM
Quick Reply: distributor O-rings/ is a O-ring, a O-ring?
