cooling problem in a 94 gsr...
Old 09-30-2003, 01:49 PM
pennies_hatchie's Avatar
Default cooling problem in a 94 gsr...
okay, just swapped in a 94 gsr into my coupe. the problem is that the motor seems to be TOO COOL. meaning that it doesnt ever get hot unless i drive around for 30 min. the temp needle is always on the bottom, barely moving from the bottom portion. it does sometimes get to the middle when i go on the hwy, but when i get off, the temp needle goes back down. i checked my fan and it doesnt seem to even blow. im just worried there might be something wrong. my conclusion is that maybe the thermostat is sticking and letting coolent flow constantly. also when its cold, vtec doesnt work, but does work after driving for a bit. any suggestions. thanks in advance
Old 09-30-2003, 01:53 PM
owen_the_soyboy's Avatar
Default Re: cooling problem in a 94 gsr... (pennies_hatchie)
swap in a working thermostat.
does your fan stay on constantly ? maybe your thermoswitch is making the fan come on more often than it should?
thermostats are CHEAP! (read: inexpensive)
Old 09-30-2003, 02:00 PM
Default Re: cooling problem in a 94 gsr... (owen_the_soyboy)
fan doesnt come on cause its so cool..
maybe because i live in WI and now its cold as hell..
but it should still get hot..
Old 09-30-2003, 03:04 PM
madman604's Avatar
i say replace the thermostat first.
Old 10-06-2003, 06:31 PM
Adachi's Avatar
Default Re: (Turbo E)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E &raquo;</TD></TR><TR><TD CLASS="quote">i say replace the thermostat first.</TD></TR></TABLE>
Your thermo is most likely stuck open.. just replace it.. i bet when you pull it out it'll be stuck open. Good Luck.
jdm_xsi206
03-16-2011 12:59 PM
aasaa666
05-31-2010 07:15 AM
jth8448
02-05-2008 09:55 PM
z6honda
30
02-18-2006 09:07 AM
tianporn
07-29-2005 11:44 PM
Quick Reply: cooling problem in a 94 gsr...
