EK B16A2 Swap Throttle Cable
I have a 1999 Honda Civic EX Coupe 5 Speed and I am doing a OBD2 USDM B16A2 swap. My qustion is what bracket and/or cable will I need? I know there are lots of post on this subject but they all have "JDM IM, GSR IM, OBD0 IM, ETC" They all go off topic. I heard a 99-00 SI throttle cable will work on my stock gas padel and the D16Y8 cable braket. Is this true?
Re: EK B16A2 Swap Throttle Cable
If you have a stock intake manifold on the USDM B16A2, then use the OE '99-00 Civic Si throttle cable and the OE B16A2 throttle cable bracket (P2T). If you have a non-stock intake manifold, tell us what you have and the proper suggestions can be provided.
The Y8 (Civic EX cable will not work. You will need the DOHC Civic Si cable. The factory part number is: 17910-S04-L02.
gapergurlie_18
10-23-2008 05:22 PM
