97 civic hx boot/axle help
Old 06-19-2011, 08:25 PM
rawrjaay's Avatar
Default 97 civic hx boot/axle help
So i took off all 4 rims to get them powder coated, and on the back of the rim was grease (front passenger side)
and so i looked and the boot was ripped and wasnt completely on the axle.
so does this mean i can replace the boot?
or do i have to buy the whole axle(which should come installed with the boot and grease) and install the whole axle on the car.?
EDIT** it looks like only the boot that is ripped is the one connected to the brake pad
the other boot looks fine. the boot is cut in half because i pulled it and it split from half way
Old 06-19-2011, 08:31 PM
GDD Member
slomofo's Avatar
Default Re: 97 civic hx boot/axle help
Might as well replace the whole axle since the boot costs a couple bucks less than a whole new axle.
Old 06-19-2011, 08:37 PM
rawrjaay's Avatar
really?
ummm ok is there a DIY on removing the passenger side axle and installing a new one?
im not to sure on the cheapest place to get an axle... hmmmm
Old 06-19-2011, 08:42 PM
alphalanos's Avatar
Honda OEMs are like $250, and thats just for like a half axle. Doesnt include the inner cv joint. at least where I got it. Autozone are like 100 or so per axle, but they have been known to be crappy.
There are a couple DIY on here but to sum it up, unstake axle nut with a chisel and hammer, get a big breaker bar + long pipe and crack the axle nut loose while the car is on the ground. Jack it up, remove wheel, use mallet to knock the axle out of hub, unbolt upper ball joint nut, unbolt tie rod nut, swing hub out of the way. use large pry bar to remove inner joint from trans.
Old 06-19-2011, 11:58 PM
rawrjaay's Avatar
you make it sound so easy. lol
but i seen a DIY on this forum and there was a whole lot more steps on there lol that i seen ahahah
thank tho bro, i appreciate it alot
taimysho0
07-08-2009 01:29 PM
ShinotakuX
26
10-18-2008 06:38 PM
athoughts
16
09-27-2005 12:49 PM
Keewun
12-20-2004 04:21 AM
hadookn
02-06-2002 12:19 PM
Quick Reply: 97 civic hx boot/axle help
