96-00 Civic EX Power Door Locks Problem: Only locks sometimes Driver Side
Old 01-11-2005, 09:52 PM
all stock's Avatar
Default 96-00 Civic EX Power Door Locks Problem: Only locks sometimes Driver Side
Before you think you can increase your postcount by 1 by saying: it's the safety locking mechanism so you don't lock your keys in your car - that is NOT what I'm talking about.
Setup:
Viper 690VX Alarm
EX Civic, OEM door locks, OEM radio
Problem:
Driver side door will lock/unlock about 5% of the time.
Intro:
Just today, getting out of my car, I noticed the driverside door lock unlocked. Normally it is always locked due to the Viper feature that locks the door when the keys are turned to the ON position. I thought to myself - that was strange and then turned on the alarm. The driverside door didn't lock! Weird...I manually locked it, alarmed the car and continued on my way.
Diagnosis:
Removing the door panels, the driverside lock attempts to lock, it appears there is not enough force generated to pushover the lock most of the time via the metal bars. I hooked up the OEM power door lock switch and proceeded to lock and unlock the door with this mechanism. The same results appeared. Most of the time, the metal bar moves, but it does not seem like enough force is being generated to pushover the lock. Finally, manual locking does not seem much more difficult than any other time prior to when the lock was working. Passenger side locks 100% of the time.
Other contributing factors:
It rained for 10 days here - damn you So Cal.
I have a feeling it could be the powerdoor lock motor, but I was informed that these rarely fail. And the rain could be a contributing factor, but in what way? Connections seem relatively dry, and the metal bar moves, so would the motor still respond regardless of a short?
Thanks for reading.
Old 01-11-2005, 10:25 PM
all stock's Avatar
Default Re: 96-00 Civic EX Power Door Locks Problem: Only locks sometimes Driver Side (all stock)
Problem Solved.
Old 01-11-2005, 10:49 PM
ErrDizzle's Avatar
the door should only lock and unlock when the door is closed.
Old 01-11-2005, 11:19 PM
lone's Avatar
Default Re: 96-00 Civic EX Power Door Locks Problem: Only locks sometimes Driver Side (a_kaibigan)
how did you fix this problem. the same thing happens to my passenger side door.
Old 01-11-2005, 11:24 PM
b e e's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all stock &raquo;</TD></TR><TR><TD CLASS="quote">Problem Solved. </TD></TR></TABLE>
how'd you solve the problem?
Old 01-12-2005, 10:07 PM
all stock's Avatar
Default Re: 96-00 Civic EX Power Door Locks Problem: Only locks sometimes Driver Side (r0semary)
wire connector going to the door lock motor was dirty and wet. cleaned and fixed.
if you're having similar problems, i'd get the connectors. also, if you dont' have an aftermarket alarm, it could be the actuators.
Old 01-12-2005, 10:15 PM
knockout's Avatar
awesome, my cars driver side has been like this, been trying to fix it, thanks for the help!
Old 01-15-2005, 12:49 AM
blinkcentral's Avatar
Holy ****...I'm in So Cali too and my power doors locks started to act weird after the rain. I also have a viper alarm. Thanks for the info. I will try it. Hopefully it will work.
EBP_Em1
Honda Civic (2006 - 2015)
09-21-2015 04:56 PM
RACEPAK
Audio / Security / Video
05-08-2009 05:53 PM
birds4us
Honda Civic (2001 - 2005)
08-31-2008 10:17 PM
aimbot
07-11-2008 08:09 AM
snoozie978
05-28-2008 07:09 PM
Quick Reply: 96-00 Civic EX Power Door Locks Problem: Only locks sometimes Driver Side
