1997 Civic Power Door lock problem
Old 04-08-2012, 02:23 PM
thebriarman's Avatar
Default 1997 Civic Power Door lock problem
My driver's door actuator went bad, (grinding noises) so I replaced it. Now, the door locks don't work properly. On "lock" the driver's door doesn't lock, on "unlock" the driver's door won't unlock. Same problem with remote entry. Other doors will lock but not unlock when driver's door power lock is pressed. If I unplug the actuator, the other doors work fine. I plug it in, none of the door locks work.
Is there something to program? Any help would be much appreciated.
Old 04-08-2012, 02:26 PM
The Grumpiest
grumblemarc's Avatar
Default Re: 1997 Civic Power Door lock problem
You replaced the actuator with what? Trying to understand what could have gone wrong if you replaced like for like. Installation is the reverse of removal.
Old 04-08-2012, 02:38 PM
motegicivic's Avatar
Did you use an oem part? should be plug and play.
Just to be straight, when you use the inside lock/unlock button what happens, nothing at all?
Old 04-08-2012, 05:31 PM
Thanks, gentlemen.
Now you know my confusion and frustration. I pulled out the old and put in a new. It was not a Honda part, it was aftermarket from Advance Auto Parts, http://shop.advanceautoparts.com/web...hedFrom=header. It looks the same, fits the same.
I hooked it up and the door locks operated trying to unlock but would not stay unlocked, went right back to locked. If I hit unlock, the locks unlock then, immediately, return to locked. Same thing happens with the keyless remote. The doors will not unlock.
If I unhook the actuator, the other three doors operate fine with both the unlock/lock button in the car and with the keyless remote.
Thanks
Old 04-08-2012, 06:21 PM
Strange so with the new one it will try to unlock and then lock again?
I am wondering if the one you got is the wrong part or defective.
Old 04-08-2012, 06:46 PM
R.I.P. Mark
MRGRIM's Avatar
let the new actuator just hand not connected to the lock and try ...
this sounds like the actuator is not adjusted correct and when unlocking its not allowing it to travel full stroke and so resets back to lock
Old 04-09-2012, 07:53 AM
MRGRIM,
That's what it seems like. It doesn't un-lock fully. I can hold the lever down and then it will stay down (unlocked) but, on it's own, it doesn't operate properly. Maybe the actuator is defective. I thought it was something in the system. I'll pull it out and exchange it and see if that corrects the problem.
Old 04-09-2012, 10:06 AM
Yes swap it out and see if it works.
Vic3261
Honda Civic (2001 - 2005)
06-17-2020 10:00 PM
Berge9798
01-15-2009 05:50 AM
SportEL
10-20-2007 03:11 PM
MADEINIRAQ
08-25-2004 07:59 PM
Quick Reply: 1997 Civic Power Door lock problem
