1992 Civic Dx will not start(fuel pump relay?)
Old 07-25-2012, 06:17 AM
hondachick4life's Avatar
Default 1992 Civic Dx will not start(fuel pump relay?)
We just picked up a civic over the weekend and we were able to drive it almost to our house. we stopped to let the engine cool b/c at the time it had a valve cover gasket leak. anywho, we installed a new ignition because we found the old one to be busted and no longer attached to the column.
It fired up on the 3rd try last night and we turned it off and cranked it again, no problem.
This morning my husband said that it would start up at all. He doesn't hear the fuel pump at the turn of the key.
WE just paid 300 bucks for the ignition and we don't want to pay for a fuel pump. How often does the fuel pump relay go out and could that be the culprit?
Thanks!
Old 07-25-2012, 06:31 AM
salaamq's Avatar
Default Re: 1992 Civic Dx will not start(fuel pump relay?)
Check the main relay, its a common problem with hondas.
Old 07-25-2012, 06:35 AM
Thank you. I'll let him know as he's headed to the junkyard right now.
Old 07-25-2012, 06:55 AM
Former User's Avatar
Also check fuses 24 and 13 (see FAQs sticky for fuse diagrams).
And read through the Codes sticky at the top, specifically Post 1 in that thread.
Old 07-25-2012, 07:22 AM
Thanks. I'm new here and I should have probably taken a better look around. I'm used to my other forum. I'll get used to this one I'm sure. I like the way the FAQ sticky is set-up here; very helpful!
greyEG
05-30-2013 07:01 PM
vee-spec
03-23-2010 07:37 PM
Jonny Rocket
12-06-2009 07:04 PM
d16y8delsol
01-06-2006 02:32 PM
Chuckyb
12-11-2004 05:45 AM
Quick Reply: 1992 Civic Dx will not start(fuel pump relay?)
