105300 cam in my Y8 are teh valve specs still teh same?
Old 09-08-2006, 07:54 AM
The Lobster's Avatar
Default 105300 cam in my Y8 are teh valve specs still teh same?
I just did a valve adjustment on my y8 head with the zex "stage 3" came. After it was done valve tapping was way louder.
are teh specs the same with oem vs aftermarket cams?
Old 09-08-2006, 08:17 AM
t0p_sh0tta's Avatar
Default Re: 105300 cam in my Y8 are teh valve specs still teh same? (The Lobster)
No.
Old 09-08-2006, 08:32 AM
itsjdmbradyo!'s Avatar
Default Re: 105300 cam in my Y8 are teh valve specs still teh same? (t0p_sh0tta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Lobster &raquo;</TD></TR><TR><TD CLASS="quote">are teh specs the same with oem vs aftermarket cams?</TD></TR></TABLE>
lol DIFFERENT specs are the whole reason they make aftermarket cams, if your "stage 3" cam had the same specs as a stock cam how it make more power?
usually with higher stage cams you need valve jobs and springs/retainers.
Old 09-08-2006, 08:34 AM
t0p_sh0tta's Avatar
Default Re: 105300 cam in my Y8 are teh valve specs still teh same? (itsJDMbradyo!)
He is referring to the valve adjustment specs.
For that cam, I am not sure of the exact specs. Contact Zex, and please tell me that you have an upgraded valvetrain.
Old 09-08-2006, 09:00 AM
yes i have upgraded valve train.
isky retainers, isky springs, rev hard valves, port and polish, 3 angle valve job.
so the valve adjustment specs are the same?
Old 09-08-2006, 10:57 AM
Everyones Hero's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Lobster &raquo;</TD></TR><TR><TD CLASS="quote">so the valve adjustment specs are the same?</TD></TR></TABLE>
No. For the 100300 it should be tighter than with the stock or 100100 (or whatever their stage 1 for Y8s is).
I don't know what the specs are, but I know for a Z6 the 59100 uses the stock specs, but the 59300 uses tighter specs.
Old 09-08-2006, 11:01 AM
damn
i have it set at super tight stock specs right now
.007 for intake and .009 for exhaust. where do i find out what i should use? or should i try to email zex?
Old 09-08-2006, 11:08 AM
Default Re: (The Lobster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Lobster &raquo;</TD></TR><TR><TD CLASS="quote">damn
.007 for intake and .009 for exhaust. where do i find out what i should use? or should i try to email zex?</TD></TR></TABLE>
email zex. They'll set you straight.
Old 09-13-2006, 10:27 AM
emailed them no reply its been couple days.
Old 09-13-2006, 11:14 AM
quicksol95's Avatar
Default Re: (Everyones Hero)
i would set the specs to factory use noted on the spec card with the cam
richie
Old 09-13-2006, 01:44 PM
it is at factory specs right now but its ticking even louder. i dont have teh spec sheet as this was used.
Old 09-14-2006, 08:45 AM
zex is being gay doesnt anyoen run this cam!
Old 09-14-2006, 04:03 PM
turnsignalandy's Avatar
what type of power u making?
out of subject.........
Old 09-15-2006, 07:07 AM
not sure yet. turbo manifold,turbo coming in 3 weeks
Old 09-21-2006, 08:38 AM
well i talked to zex and they said its factory specs at .007 and .009. He told me even teh race cams are factory specs. anyone else adjust their valves different with an aftermarket cam?
Old 09-21-2006, 08:58 AM
Sleepy_Red_hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Lobster &raquo;</TD></TR><TR><TD CLASS="quote">well i talked to zex and they said its factory specs at .007 and .009. He told me even teh race cams are factory specs. anyone else adjust their valves different with an aftermarket cam?</TD></TR></TABLE>
ticking is normal, the lobes are more agressive
Old 09-21-2006, 09:28 AM
but its really loud. like when im in the car and i rev the motor i can actually hear it clearly over my exhaust.
Pfieff
01-21-2009 12:14 PM
krazeenoy
06-12-2007 06:26 PM
krazeenoy
05-19-2007 04:50 PM
all-mtr-teg
01-06-2007 09:57 PM
hondadriver
10-01-2006 09:12 AM
Quick Reply: 105300 cam in my Y8 are teh valve specs still teh same?
