Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Replacing Oil Pan
Old 05-05-2010, 08:24 PM
EM2_PLo's Avatar
Default Replacing Oil Pan
Here's the scenario. I took my car ONCE to get the oil changed, because I didn't have time and didn't want to drive it out of town with old oil. I just recently changed it myself and notice the oil pan was stripped . I went ahead and just put in an over sized drain plug for now as a quick fix until I get paid next week. My questions are, is it necessary to replace the oil pan? how did this happen? Was it over torqued? How can I prevent this from happening again?
Old 05-05-2010, 09:59 PM
00falcon's Avatar
Default Re: Replacing Oil Pan
did you take it to a honda dealer?
Old 05-05-2010, 11:53 PM
EM2_PLo's Avatar
No I had taken it to a local wal-mart tire and lube
Old 05-06-2010, 06:09 AM
2002civicrider's Avatar
Probably was over torqued. I've had to replace mine before.
Old 05-06-2010, 08:40 AM
00falcon's Avatar
i know a guy who went to wally world for oil changes and they blew his motor up... had to put in a new one
Old 05-06-2010, 09:34 AM
EM2_PLo's Avatar
lmao blew the motor up? how did they do that?
EM2_PLo's Avatar
So then I should be tightening the drain plug with a torque wrench?
Old 05-06-2010, 12:54 PM
theineffable's Avatar
it's not hard to strip the threads...i would use a torque wrench...
if it's not stripped badly, you might get away with retapping the drain hole. do this with the pan removed else you'll drop metal bits into the oil...
Old 05-06-2010, 01:21 PM
97twodoor's Avatar
Proper torque FTW
D17A2/ D17A6: 39 NM (29 FT. LBS.)
D17A1: 44 NM (33 FT. LBS.)
Old 05-06-2010, 01:34 PM
EM2_PLo's Avatar
Damn that sucks I guess I'll start using a torque wrench. I'm probably just gonna replace the oil pan instead. Thanks.
AZ-Accord
11
04-11-2013 05:16 PM
muscleman0745
06-03-2010 05:05 AM
miataguy
11
02-20-2007 05:00 PM
hondaboy4life
09-29-2006 08:01 AM
shming123
04-16-2003 11:12 AM
Quick Reply: Replacing Oil Pan
