Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
How long does it take to take you guys to change the Timing Belt?
Old 04-06-2010, 08:35 AM
teler86's Avatar
Default How long does it take to take you guys to change the Timing Belt?
I have done timing belts before, a long time ago on my B16 CRX and more recently on VW's/Audi's so I have experience doing it. How long does it usually take you guys to change the belt, pump, and tensioner.
The Civic is a DX so non-vtec if that matters.
Thanks.
Old 04-06-2010, 09:01 AM
Pothole987's Avatar
Default Re: How long does it take to take you guys to change the Timing Belt?
an hour or two if you know what your doing and have all the tools right there
97twodoor's Avatar
All Data Labour says 2.7 hours which i think is pretty accurate.
Old 04-07-2010, 12:10 AM
boxeocampeon's Avatar
do you have an impact gun? that will cut a lot of time off and make it much easier
Old 04-07-2010, 12:19 AM
Plead da Fif
It Wasn't Me's Avatar
It's best to plan on spending the day doing it. You never know what other kind of "problems" you may run into.
I can't count the times I've ended up spending an entire day on something that should have only taken a few hours. Something's seized, something breaks, something strips.. .. there always seems to be something.
Old 04-08-2010, 01:18 PM
BYUFAN's Avatar
Just did this yesterday. It took me all day. I had to replace the crankshaft oil seal there was a lot of oil down there so that ate up some time. Also my lower timing belt cover had a big crack in it and fell apart when I took it off So I had to run to Honda to get a new one.
Like the guy above me said. Just plan a day. Something will hold you up.
Old 04-09-2010, 06:21 AM
ken9's Avatar
I have an Impact gun but it "fail." It didn't work to well. Probably got crappy one.. = (
Old 04-09-2010, 10:01 AM
GDD Member
slomofo's Avatar
About an hour for Accords/Civics/Integra with waterpump on D/B/F/H series engines.
Hour and a half for Accord V6.
Two hours for Accord V6 with waterpump
Audi 1.8T 3-4hrs. with waterpump
Audi 3.0 4-5hrs. with waterpump
Audi 2.7TT 4-5hrs. with waterpump
VW 1.8T 45 minutes with waterpump
VW 2.0 45 minutes with waterpump
Old 04-10-2010, 11:19 AM
vettefan77's Avatar
only thing that ever held me up was the crank pully bolt - use a decent impact gun & a short extension, should zip it off. if your gun's no good, you can pick a decent Ingersol rand at a pawn shop for $40 or so.
Old 04-10-2010, 12:43 PM
GDD Member
slomofo's Avatar
Old 08-27-2013, 07:34 AM
James Harmon's Avatar
this guy has had my car since fri its now tue well I give him 1 day for paets and just 1guy.i added fuel filter & oil change
Old 08-27-2013, 07:36 AM
JC8643's Avatar
Once youre in there you should always change all seals dude. Best time ever! Crank, Cam, Oil, Water pump, Timing belt. Valve cover, O-rings. why bother taking those things apart again ><
Rick1t
18
01-18-2010 04:10 PM
Campee
05-04-2005 10:05 AM
BlackGser
04-27-2005 11:00 AM
Jeff99Base
09-07-2003 07:50 AM
VTECTIME
11
01-12-2003 08:59 PM
Quick Reply: How long does it take to take you guys to change the Timing Belt?
