Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2002 Civic LX Cylinder 1 & 3 misfire
Old 02-14-2015, 07:41 PM
gv642995's Avatar
Icon2 2002 Civic LX Cylinder 1 & 3 misfire
Hello everyone, i would like to start off by thanking you for taking the time to read this.
About a week ago my check engine light turned on and the car began to tremble slightly more than before. I later purchased a scanner to check what the problem was and it said Cylinder 1 misfire detected (P0301). I then switched the first Ignition coil pack with the third one to see if it was that. The scanner then displayed that there was a misfire in cylinders 1 & 3. However, after switching the ignition coil packs back to their place the scanner still said that there were misfires in cylinders 1&3, as well as a message that said "Random - Multiple misfires detected (P0300)". I replaced the first ignition pack after noticing that it was torn from the rubber end that connected to the spark plug. After driving it around the car stopped trembling for a bit and seemed to become more powerful in terms of acceleration, but began to tremble again after a few minutes. When i got home, i reconnected the scanner and it gave me the same codes (P0300, P0301, P0303). Throughout the entire this time, the check engine light remained on. What could be the issue?
Old 02-14-2015, 08:27 PM
Former User's Avatar
Default Re: 2002 Civic LX Cylinder 1 & 3 misfire
How old are the spark plugs? Did you inspect them? Gapped properly?
Old 12-11-2015, 06:49 AM
mattcadman's Avatar
What brand coils and plugs did you use as a replacement?
mattcadman's Avatar
Not that this helps your problem...but I believe that the check engine light will not go off until you turn it off with the scanner. Even if you remedy the problem.
bobinyelm
08-02-2017 09:28 AM
Apple395
09-01-2013 09:04 AM
ron spencer
18
07-20-2013 07:34 PM
Wwisuri
01-28-2013 10:47 AM
BassHunter
11-01-2006 05:59 PM
Quick Reply: 2002 Civic LX Cylinder 1 & 3 misfire
