HELP!!!!!!!!
Old Jan 22, 2013 | 11:01 AM
Wwisuri's Avatar
Icon6 HELP!!!!!!!!
I have a 2002 Honda Accord Ex v6 with 212,000 highway miles. My check engine light came on a few months ago along with my tcs light. I took it to a mechanic who said I have all 1-6 cylinder misfires. He cleaned my injectors and replaced all spark plugs for $220 ( rip off I know). Three days later my check engine and tcs lights came on again. So I hooked it up to the code reader which read back cylinder 4 misfire. I then replaced the cylinder 4 ignition coil. Still no luck when I start my car it bogs out like I'm running out of gas (which I'm not). I took the car to the Honda dealership paid $85 for them to suggest a valve adjustment and then they will check the car again. They pulled engine fault codes po300-p0306 and random cylinder misfire. I'm running out of time my tags expired in December and I need a smog to get my sticker. Any suggestions where I go from here?
Old Jan 22, 2013 | 04:07 PM
jdowen2's Avatar
Default Re: HELP!!!!!!!!
p0306 is #6 cylinder misfire. Swap coils with another cylinder, clear codes, and restart and drive. If trouble follows the coil pack is bad.
Old Jan 22, 2013 | 07:05 PM
NilesLindenmuth's Avatar
Do exactly that
Old Jan 28, 2013 | 06:26 AM
Wwisuri's Avatar
The coils tested fine the dealership suggested a valve adjustment I bought the car with 70k it now has 213k I've never had a valve adjustment
Old Jan 28, 2013 | 06:35 AM
92 civic ex 4dr's Avatar
Of course the dealership recommends a valve adjustment (wouldn't hurt though) that's bookoo bucks for them to year the heads off an engine. I would tear it down myself and take the heads to a machine shop. Save yourself some money.
Posted from Honda-tech.com App for Android
Old Jan 28, 2013 | 10:47 AM
MAD_MIKE's Avatar
MM Gruppe B
Do you have your last emissions test report?
Was your NOx creeping up? A misfire can be caused by a lean condition, if the EGR system has never been cleaned it may just be time to clean it out, if this is the case then there isn't a problem with the ignition system. It may simply be an issue with the EGR system not flowing enough, which then can cause a misfire.
bigfrank1130
Jan 21, 2015 03:52 AM
SuppaClean96Ex
Feb 1, 2009 08:51 PM
mbsi
May 7, 2008 08:57 AM
mbsi
Honda Civic (2006 - 2015)
May 5, 2008 07:24 PM
mbsi
May 3, 2008 01:10 PM
